Home » Newcomers » Newcomers » How to change @author default field in Javadoc
How to change @author default field in Javadoc [message #803224] Mon, 20 February 2012 22:52 Go to next message
When I type /** and press return to insert a Javadoc comment, Eclipse automatically writes for me
* @author Bobby Brown
because I am using the computer of my good friend Bobby Brown. Is there a setting for me to change so that it writes a different name in the author field?
Thanks.
Re: How to change @author default field in Javadoc [message #803340 is a reply to message #803224] Tue, 21 February 2012 02:58 Go to previous messageGo to next message
> * * @author Bobby Brown
> the author field?
Start Eclipse with the following VM argument: -Duser.name=YourName
Dani
> Thanks.
Re: How to change @author default field in Javadoc [message #803388 is a reply to message #803340] Tue, 21 February 2012 04:28 Go to previous messageGo to next message
FOllow these steps should
create a user with your name.
login to your user and start writting code.
change computer name with your name.
It should fix your issue.
Re: How to change @author default field in Javadoc [message #803534 is a reply to message #803388] Tue, 21 February 2012 08:10 Go to previous messageGo to next message
On 2012.02.21 2:28, Bimlesh Sharma wrote:
> FOllow these steps should create a user with your name.
(Yeah, Bobby Brown will love that idea.)
Re: How to change @author default field in Javadoc [message #803607 is a reply to message #803224] Tue, 21 February 2012 10:00 Go to previous messageGo to next message
> author field?
> Thanks.
There's also an alternative method given at "Alternative" in the note at
this link. This method will achieve the same result, but it will also
contaminate the workspace on Bobby's computer (but only that workspace).
http://www.javahotchocolate.com/notes/eclipse.html#author
Re: How to change @author default field in Javadoc [message #957444 is a reply to message #803224] Thu, 25 October 2012 04:24 Go to previous messageGo to next message
Simply go to:
Window - Preferences - Java - Code Style - Code Templates - Comments - Types - Edit... and change ${user} to whatever you want.
Also go to:
Window - Preferences - Java - Editor - Templates - @author - Edit... and change ${user} to whatever you want.
Re: How to change @author default field in Javadoc [message #1739693 is a reply to message #803224] Wed, 03 August 2016 20:01 Go to previous message
To change what shows after the existing @author, this works:
Window - Preferences - Java - Code Style - Code Templates - Comments - Types - Click Edit and change ${user} to what you want.
Previous Topic:JRE Crash creating Eclipse (Mars x32bit) GWT project on Windows 7 Enterprise
Next Topic:Eclipse takes very long time to delete files during build.
Current Time: Mon Nov 03 21:54:00 EST 2025
Powered by FUDForum. Page generated in 0.09297 seconds
