Home » Modeling » Epsilon » Getting links with EGL
Re: Getting links with EGL [message #1739370 is a reply to message #1739367] |
Sat, 30 July 2016 20:08   |
@gmf.diagram(foo="bar", rcp="false", onefile="true", diagram.extension="ccase")
class CCase {
val Transition[*] transitions;
val Function[*] functions;
@gmf.node(label="name", label.text="Function", border.color="43,106,215")
class Function{
@gmf.compartment
val Parameters[*] declarativePart;
@gmf.compartment
val Statements[*] executablePart;
@gmf.node(label="name", figure="rectangle", border.width="1", label.icon="true",label.readOnly = "true", label.placement="internal")
class Parameters{
attr String name;
attr ParameterType type;
@gmf.node(label="description", label.icon="true", label.placement="internal")
abstract class Statements{
attr String description;
attr String code;
@gmf.link(source="source", target="target", incoming="true", target.decoration="arrow", color="0,0,0", width="1")
class Transition{
attr String name = "Connection";
ref Statements source;
ref Statements target;
Basically, inside of "Function" it's possible add many statements and parameters. The parameters can be linked by one Transition. I have to know where the diagram starts and the order of the statements linked.
Re: Getting links with EGL [message #1746594 is a reply to message #1746521] |
Tue, 01 November 2016 10:30   |
Hi Dimitris,
#1It's definitely something that I'l like to do.
#2 This is my .emf file updated:
@namespace(uri="crystal", prefix="crystal")
package crystal;
@gmf.diagram(foo="bar", rcp="false", onefile="true", diagram.extension="crystal")
class Crystal {
val SelectorTransition[*] selectorTransitions;
val Procedure[*] procedures;
val AnonymousBlock[*] blocks;
//Subprograms
@gmf.node(figure="rectangle", border.width="1", label.readOnly = "true")
abstract class Subprograms{
attr String name;
@gmf.node(label="name", label.text="Procedure", border.color="255,13,13") //vermelho
class Procedure extends Subprograms {
@gmf.compartment
@gmf.compartment
val Parameters[*] parameters;
@gmf.compartment
@gmf.node(label="name", label.text="Function", border.color="25,191,108") //azul
class Function extends Subprograms {
@gmf.compartment
@gmf.compartment
@gmf.compartment
val Parameters[1] returnPart;
@gmf.compartment
@gmf.node(label="name", label.text="Anonymous Block", border.color="43,106,215", border.style="dash") //verde
class AnonymousBlock extends Subprograms {
@gmf.compartment
@gmf.compartment
//Parameters
abstract class Parameters{
attr String name;
@gmf.node(label.text="Data Type")
class DataType extends Parameters{
attr String className ="DataType";
attr DataTypeOptions options;
attr int precision = 1;
attr int scale = 0;
@gmf.node(label.text="Collection")
class Collections extends Parameters{
attr String className ="Collection";
attr String code = "TYPE name IS TABLE OF NUMBER INDEX BY VARCHAR2(20)";
attr String typeName = "collectionTypeName";
@gmf.node(label.text="Record")
class Records extends Parameters{
attr String className ="Record";
attr String code = "TYPE recordType IS RECORD (id number(5), name varchar2(25), lastName tableA.last_name%type)";
attr String typeName = "recordTypeName";
@gmf.node(label.text="Cursor")
class Cursor extends Parameters {
attr String className ="Cursor";
attr String cursorQuery = "selectStatement";
//Statements
attr String description = "Description";
attr boolean isStart;
@gmf.node(figure="rectangle")
class Expression extends Statements {
attr String className ="Expression";
attr String value = "Type the expression here";
class Exception extends Statements{
attr String className ="Exception";
attr String code = "EXCEPTION WHEN no_data_found THEN DBMS_OUTPUT.PUT_LINE('There isnt data registered')";
class If extends Statements{
attr String className ="If";
attr String condition = "Type the IF condition";
@gmf.compartment
val Statements[*] ifs;
@gmf.compartment
val Statements[*] elses;
class Case extends Statements{
attr String className ="Case";
@gmf.compartment
val Selector[*] cases;
@gmf.node(figure="rectangle", label="description", label.icon="true", label.placement="internal")
class Selector {
attr String className = "Selector";
attr String condition = "Type the condition for this Selector";
@gmf.compartment
val Statements[*] caseStatements;
class Insert extends Statements{
attr String className ="Insert";
attr String code = "INSERT INTO tableA (id, name) VALUES (1, 'example')";
class Update extends Statements{
attr String className ="Update";
attr String code = "UPDATE tableA SET name = 'example' WHERE id = 1";
class Delete extends Statements{
attr String className ="Delete";
attr String code = "DELETE FROM tableA WHERE ID = 1";
class Select extends Statements{
attr String className ="Select";
attr String code = "SELECT * FROM tableA WHERE id = 1";
class While extends Statements{
attr String className ="While";
attr String condition = "Type the WHILE condition";
@gmf.compartment
val Statements[*] whileStatements;
class For extends Statements{
attr String className ="For";
attr String counter = "Type the name of the FOR counter";
attr ForCounter typeCounter;
attr int lowestNumber = 0;
attr int highestNumber = 0;
@gmf.compartment
val Statements[*] forStatements;
class Loop extends Statements{
attr String className ="Loop";
attr String breakCondition = "Type the break condition for LOOP";
@gmf.compartment
val Statements[*] loopStatements;
class Open extends Statements{
attr String className ="Open";
attr String cursorName = "cursorName";
class Fetch extends Statements{
attr String className ="Fetch";
attr String variableName = "variableCursor";
class Close extends Statements{
attr String className ="Close";
class CallProcedure extends Statements{
attr String className ="CallProcedure";
attr String nameSubroutine;
class CallFunction extends Statements{
attr String className ="CallFunction";
@gmf.link(source="source", target="target", incoming="true", target.decoration="arrow", color="0,0,0", width="1", label="name", label.text="Statement Connection", label.icon="true")
class Transition{
attr String name = "Statement Connection";
@gmf.link(source="source", target="target", incoming="true", target.decoration="arrow", color="0,0,0", width="1", label="name", label.text="Case Connection", label.icon="true")
class SelectorTransition{
attr String name = "Case Connection";
ref Selector source;
ref Selector target;
enum ParameterType {
IN = 0;
OUT = 1;
IN_OUT = 2;
enum ForCounter {
NORMAL = 0;
REVERSE = 1;
enum DataTypeOptions {
CHAR = 0;
NCHAR = 1;
NVARCHAR2 = 2;
VARCHAR2 = 3;
LONG = 4;
RAW = 5;
LONG_RAW = 6;
NUMBER = 7; //can modify the precision and scale
NUMERIC = 8; //can modify the precision and scale
FLOAT = 9;
DEC = 10; //can modify the precision and scale
DECIMAL = 11; //can modify the precision and scale
INTEGER = 12;
INT = 13;
SMALLINT = 14;
REAL = 15;
DOUBLE = 16;
DATE = 17;
TIMESTAMP_WITH_TIME_ZONE = 18;
TIMESTAMP_WITH_LOCAL_TIME_ZONE = 19;
INTERVAL_YEAR_TO_MONTH = 20;
INTERVAL_DAY_TO_SECOND = 21;
BFILE = 22;
BLOB = 23;
CLOB = 24;
NCLOB = 25;
ROWID = 26;
UROWID = 27;
Cheers.
Re: Getting links with EGL [message #1752340 is a reply to message #1752338] |
Sun, 22 January 2017 06:19  |
Actually, this seems to be quite straightforward. You need to locate the Polyline Decoration that corresponds to the arrow of interest in your .gmfgraph model and turn its line kind to LINE_DASH. If you do this manually, you'll then need to right-click on your .gmfmap model and select "Create generator model ..." and then right-click on your .gmfgen and select "Generate diagram code".
Dimitris
Current Time: Sat Jul 26 12:51:46 EDT 2025
Powered by FUDForum. Page generated in 0.10162 seconds
