DataSourceCredentialVerifier [message #1739349] |
Sat, 30 July 2016 07:08  |
I'm using the NEON R release (on linux mint, using OpenJDK and postgresql fyi), and as far as I can tell, there's no database authentication mechanism provided out-of-the-box as was in previous version (a la DataSourceSecurityFilter). So I rolled up my sleeves and wrote one.
As can be expected, I duplicated the ConfigFileCredentialVerifier. What surprised me though was that the verification is done on the 'client' side, not in the server. Because of that, I had to add postgresql driver maven dependencies to the client, which somehow sits with me a bit wrong. I got it working, but is necessary to do that? I remember seeing this behaviour in earlier versions in the RAP client.
Also, it strikes me as a kind of core piece of functionality. I presume you (at BSI) already have already written something to this effect. If so, is it scheduled for a future release?
In the mean time, here's what I did. It seems to work (for me), but please scrutinize if I can improve anything.
@Bean
public class DataSourceCredentialVerifier implements ICredentialVerifier {
private static final String SELECT_USER_SQL = ""
+ "SELECT pw_hash, pw_salt"
+ " FROM users "
+ " WHERE username = ? "
+ " AND (blocked IS NULL OR blocked = false) "
+ " AND (failed_login_attempts < ? OR id = 1) ";
private static final String UPDATE_RETRY_COUNT_SQL = ""
+ "UPDATE users "
+ " SET failed_login_attempts = COALESCE(failed_login_attempts, 0) + 1 "
+ " AND id != 1 ";
private static final int DEFAULT_MAX_RETRIES = 5;
private static Logger logger = LoggerFactory.getLogger(DataSourceCredentialVerifier.class);
private String m_dbUrl;
private String m_dbUsername;
private String m_dbPassword;
private Integer m_maxRetries;
private Connection m_connection;
@PostConstruct
private void init() {
m_dbUrl = BEANS.get(JdbcUrlProperty.class).getValue();
m_dbUsername = BEANS.get(JdbcUsernameProperty.class).getValue();
m_dbPassword = BEANS.get(JdbcPasswordProperty.class).getValue();
m_maxRetries = BEANS.get(MaxRetriesProperty.class).getValue();
try {
m_connection = DriverManager.getConnection(m_dbUrl, m_dbUsername, m_dbPassword);
} catch (SQLException e) {
logger.error("Unable to connect to database", e);
@PreDestroy
private void destroy() {
if (m_connection != null) {
try {
m_connection.close();
// NOP
public int verify(String username, char[] password) throws IOException {
int result = AUTH_FORBIDDEN;
try (PreparedStatement stmt = m_connection.prepareStatement(SELECT_USER_SQL)) {
stmt.setString(1, username);
stmt.setInt(2, m_maxRetries != null ? m_maxRetries.intValue() : DEFAULT_MAX_RETRIES);
logger.debug("{}", stmt);
stmt.execute();
ResultSet rs = stmt.getResultSet();
if (rs != null && rs.next()) {
String pwHash = rs.getString(1);
String pwSalt = rs.getString(2);
if (!StringUtility.isNullOrEmpty(pwHash) && !StringUtility.isNullOrEmpty(pwSalt)) {
byte[] hash = SecurityUtility.hash(Base64Utility.decode(
String.valueOf(password)), Base64Utility.decode(pwSalt));
if (Arrays.equals(hash, Base64Utility.decode(pwHash))) {
result = AUTH_OK;
logger.error("Unable to fetch authentication info from db", e);
result = AUTH_FAILED;
if (result == AUTH_FAILED && !StringUtility.isNullOrEmpty(username)) {
// attempt to increment the failed retry count
try (PreparedStatement stmt = m_connection.prepareStatement(UPDATE_RETRY_COUNT_SQL)) {
int updates = stmt.executeUpdate();
if (updates > 0) {
logger.info("retry count for {} incremented. {} row updated.", username, updates);
logger.warn("Unable to update retry count for user " + username, e);
return result;
public static class JdbcUrlProperty extends AbstractStringConfigProperty {
public String getKey() {
return "auth.jdbc.url";
public static class JdbcUsernameProperty extends AbstractStringConfigProperty {
return "auth.jdbc.user";
public static class JdbcPasswordProperty extends AbstractStringConfigProperty {
return "auth.jdbc.password";
public static class MaxRetriesProperty extends AbstractPositiveIntegerConfigProperty {
return "auth.maxretries";
String username = "admin";
String password = "manager";
byte[] salt = SecurityUtility.createRandomBytes();
byte[] hash = SecurityUtility.hash(Base64Utility.decode(password), salt);
System.out.printf("The salt is: [%s]\n", Base64Utility.encode(salt));
System.out.printf("The hash for %s/%s is: [%s]\n", username, password, Base64Utility.encode(hash));
FUDForum. Page generated in 0.04665 seconds
