difference between "eContents" and "eAllContents" [message #1739285] |
Fri, 29 July 2016 07:06  |
I looked at the documentation but still wondering how "EObject.eContents()" and "EObject.eAllContents()" compare.
I analyzed a random EObject instance and "EObject.eContents()" return something when "EObject.eAllContents()" returns nothing.
Thanks.
[Updated on: Fri, 29 July 2016 07:07] by Moderator
Re: difference between "eContents" and "eAllContents" [message #1739745 is a reply to message #1739285] |
Fri, 29 July 2016 08:03  |
Comments below.
On 29.07.2016 13:06, aurel pestell wrote:
> I looked in a random EObject and "EObject.eContents()" return
Well, one returns a list and the other an iterator so I'm not sure you
how concluded "nothingness" in either case because in both cases a
non-null value is definite returned. The eAllContents is basically an
iterator over the containment tree, so it will most definitely return
all the objects that are in eContents, but in addition to that, each
subtree's eContents is visited recursively.
> Thanks.
FUDForum. Page generated in 0.04211 seconds
