Ecore model support for .net [message #1739176] |
Thu, 28 July 2016 02:16  |
Using XSD we have defined the ecore model and the model,edit,editor code is generated.Now can we use these generated plugins in .net also such that we can use the same feature in .net also.
Is this a possible thing
Re: Ecore model support for .net [message #1739502 is a reply to message #1739409] |
Mon, 01 August 2016 03:43  |
Hi Jonas
It depends what you mean by "support".
If you just want a C# representation of the model then that is a
straightforward model-to-text problem that can be dealt with by
Acceleo/JET/Xtend or direct code.
If you want the full EMF run-time support for platform:, eInvoke,
eSettingDelegate, ExtendedMetaData, ... then that is a very major
undertaking. Mindless Java to C# migration might do most of it, but the
subtleties of classpaths, reflection, generics and boxing are sure to
give some excitements. (If someone really wants to do this a dilemma
will no doubt arise as to whether a more compatible EMF 3.x architecture
might evolve to exploit the experience of the last ten years.)
The author seemed to want the IDE to be ported to C# as well ....
Ed Willink
On 01/08/2016 07:10, Jonas Helming wrote:
> I do not think there is any conceptional reason, that C# could not be
> supported by EMF, it just seems to not be available at the moment. So
> you can either implement that yourself or sponsor the development.
> Best regards
> Jonas
> On 29.07.2016 11:01, naveen ramesh wrote:
>> Ok i understand it.But i have defined the ecore model and generated the
>> plugins for my model and written some additional plugins to it.So i want
>> the same design to be ported to C#.Is this can be done.
>> If no can we get the valid reason
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
FUDForum. Page generated in 0.06339 seconds
