Home » Language IDEs » ServerTools (WTP) » Re-publishing base classes in Tomcat
Re-publishing base classes in Tomcat [message #173739] Mon, 10 July 2006 05:42 Go to next message
before I switched to WTP I was working with the Sysdeo Tomcat Plugin. I
was able to transform my projects into WTP style and my application runs
within tomcat.
There is something that makes working really hard. I have got a base
project that holds my model classes and business functions. This base
project is included as J2EE module in the dynamic web project. Every
time I change something in the base project while running the
application the change can not be republished to the server.
Does anybody have a solution to this problem? I is really annoying
having to restart every time.
cheers
tOM
Re: Re-publishing base classes in Tomcat [message #173748 is a reply to message #173739] Mon, 10 July 2006 08:45 Go to previous messageGo to next message
Originally posted by: gene.rockhoppertech.com
For clarification:
I don't know what a "base project" is. This is a java project with pojos
that you want included in a dynamic web project right?
I'm doing that and it works ok. All I did was go to the web project's
properties and choose the java project as a "J2EE module dependency".
They call that a "utility" project for some weird reason.
Is that what you did?
Thomas Einwaller wrote:
> within tomcat.
> cheers
> tOM
Re: Re-publishing base classes in Tomcat [message #173755 is a reply to message #173748] Mon, 10 July 2006 10:04 Go to previous messageGo to next message
That is exactly what I did. The problem is that every time I change
something in the code of this "utility" project the server tries to
"republish" it and tells me that it can not publish the "jar" because it
is locked.
Maybe this is a problem only on windows machines. Which operating system
do you use?
cheers
tOM
Gene De Lisa wrote:
> For clarification:
>> Hi,
>> I was able to transform my projects into WTP style and my application
>> runs within tomcat.
>> cheers
>> tOM
Re: Re-publishing base classes in Tomcat [message #173849 is a reply to message #173755] Mon, 10 July 2006 16:40 Go to previous messageGo to next message
Oh my that's irritating. Same config; different results. I don't see any
mention of a "jar" in my console. I'm using the new callisto release.
You too?
I just tested this on XP.
I've gotten into the habit of inspecting
..metadata\.plugins\org.eclipse.wst.server.core
occasionally. Poke around and maybe something will tell you the problem.
> is locked.
> do you use?
> cheers
> tOM
> Gene De Lisa wrote:
>> For clarification:
>> pojos that you want included in a dynamic web project right?
>>> Hi,
>>> runs within tomcat.
>>> cheers
>>> tOM
Re: Re-publishing base classes in Tomcat [message #173925 is a reply to message #173755] Tue, 11 July 2006 13:10 Go to previous messageGo to next message
It is a known issue on Windows. My understanding is that if the JAR has
been accessed, an open handle is kept, I assume for performance reasons,
until the JAR is closed and the JAR file object garbage collected. On
Windows, this open handle is sufficient to lock the JAR file. Since the
publish operation in Web Tools tries to delete the file before creating
a new one, the publish operation fails.
The only work around I can think of at the moment is to use Eclipse 3.2
+ WTP 1.5 and temporarily link the "utility" Java file to be worked on
into the Java source folder of your Dynamic Web Project. Eclipse 3.2
supports linking beyond just the project's root folder. The servlet
spec dictates that if there are duplicate classes between
WEB-INF/classes and WEB-INF/lib, WEB-INF/classes wins. You will still
get the "locked JAR" error, but the web application will still reload
and see your changes because of the updated class in WEB-INF/classes.
Remove the link when you are "done" with the modifications.
To be investigated is whether publishing can be updated to rewrite the
JAR if it can't be deleted.
Larry
> is locked.
> do you use?
> cheers
> tOM
> Gene De Lisa wrote:
>> For clarification:
>>> Hi,
>>> runs within tomcat.
>>> cheers
>>> tOM
Re: Re-publishing base classes in Tomcat [message #174064 is a reply to message #173925] Wed, 12 July 2006 05:54 Go to previous message
Originally posted by: tei.silbergrau.com
I found out that though the message is displayed the webapp is updated and
changes effect my application immediately (without restarting).
The only thing is that the can-not-publish-because-jar-is-locked-dialog
really "nerves"
cheers
tOM
> Cheers,
> Larry
>> is locked.
>> do you use?
>> cheers
>> tOM
>> Gene De Lisa wrote:
>>> For clarification:
>>>> Hi,
>>>> runs within tomcat.
>>>> cheers
>>>> tOM
Previous Topic:web tools : html editor
Next Topic:Files with .# in my war, why?
Current Time: Wed Jul 23 01:57:35 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
