Home » Modeling » Epsilon » [Eugenia] Sub-labels into nodes and links(How to put sub-labels in nodes and links into GMF, specified in the Emfatic source code.)
[Eugenia] Sub-labels into nodes and links [message #1738973] Tue, 26 July 2016 08:39 Go to next message
I'd like to put some "sub-labels" in nodes and also in links. The online example of Eugenia does that with containment for referenced attributes, but what if the labels you want to show are simply plain attributes of the same node class ? Well, as it might be not very clear, here is an example of what I tried to write in the Emfatic source code:
@gmf.node(label="Name")
class Actor {
  id attr String[1] Name;
  @gmf.label(pattern="WCET: {0}")
  attr int[1] WCET = 1;
@gmf.link(source="source", target="target", target.decoration="arrow", width="2")
class Channel {
  @gmf.label(text="<unset>", pattern="Prod: {0}")
  attr String[1] ProdRate;
  @gmf.label(text="<unset>", pattern="Cons: {0}")
  attr String[1] ConsRate;
  ref Actor[1] source;
  ref Actor[1] target;
Not surprisingly it is not working for links (I guess a good solution would be to do the same thing as in this example). But for nodes, I don't understand why it's not working (actually, only the WCET value is printed below the "Name" label, not respecting the given pattern) . Is there a problem in my patterns ? Also is it possible to achieve all of that without doing an .eol file ?
Alex H.
[Updated on: Thu, 28 July 2016 05:26] by Moderator
Re: [Eugenia] Sub-labels into nodes and links [message #1739229 is a reply to message #1738973] Thu, 28 July 2016 10:58 Go to previous messageGo to next message
A quick look at the Eugenia source code confirms that currently @gmf.label on EAttributes is only supported for @gmf.node classes. If this is important to you, feel free to file a feature request and we'll revisit this as soon as possible.
I've tried replacing "pattern" with "label.pattern" (as in the docs [1]) and it works - could you try it?
[1]: https://www.eclipse.org/epsilon/doc/articles/eugenia-gmf-tutorial/
Re: [Eugenia] Sub-labels into nodes and links [message #1739231 is a reply to message #1738973] Thu, 28 July 2016 11:03 Go to previous messageGo to next message
Hi Alex,
According to the documentation, @gmf.label(pattern="WCET: {0}") should read @gmf.label(label.pattern="WCET: {0}") instead.
Dimitris
Re: [Eugenia] Sub-labels into nodes and links [message #1739236 is a reply to message #1739231] Thu, 28 July 2016 11:44 Go to previous message
Hi, thanks it works ! I wrongly believed that as I was already in a label annotation I haven't to write "label" again.
For label in links, it's not important to me; but less is best so if it is possible in the future to avoid the eol file for that, it would be great. So I'll probably post a feature request, with low priority Wink
Alex H.
Previous Topic:XMI to HUTN bridge
Next Topic:Eunit JunitClasses missing in jars?
Current Time: Fri Jul 25 21:09:28 EDT 2025
Powered by FUDForum. Page generated in 0.03564 seconds
