Home » Eclipse Projects » Virgo » Plan with CXF DOSGi 3.1.6 fails to start
Plan with CXF DOSGi 3.1.6 fails to start [message #1739125] Wed, 27 July 2016 11:44 Go to next message
This is my first attempt at using a Virgo plan and I'm failiing miserably Rolling Eyes
First it complained about some of the version entries not being numeric:
name="org.apache.servicemix.bundles.jaxb-impl" version="2.2.11_1"
with a file called: org.apache.servicemix.bundles.jaxb-impl-2.2.11_1.jar
So I change the file names by replacing the _ with a . (which is also what is in the bundle manifest: Bundle-Version: 2.2.11.1).
All good, the result is the attached plan, now I'm getting the following error on the very first bundle:
[2016-07-27 16:39:08.738] ERROR fs-watcher                   org.eclipse.virgo.medic.eventlog.default                         DE0003E Install failed for plan 'cxf-dosgi-plan' version '1.8.0'.
[2016-07-27 16:39:08.738] INFO  fs-watcher                   System.out                                                        org.eclipse.virgo.nano.deployer.api.core.DeploymentException: Deployment of plan 'cxf-dosgi-plan' version '1.8.0' in scope 'null' failed: bundle 'geronimo-osgi-registry' in version range '[1.1.0, oo)' not found
I copied all the JARs from the DOSGi 1.8.0 release to ext/usr and the file "geronimo-osgi-registry-1.1.jar" exists.
The contents of the bundle also states Bundle-Version: 1.1
Is the naming incorrect? Have I misunderstood plans?
Re: Plan with CXF DOSGi 3.1.6 fails to start [message #1739129 is a reply to message #1739125] Wed, 27 July 2016 11:49 Go to previous messageGo to next message
Hi Bill,
Maybe "geronimo-osgi-registry" is the bundle name, not the symbolic name?
The bundle name attribute in the plan is not expected to contain the Jar file name, but rather the symbolic name of the bundle.
With respect to the version, you can safely omit it as it is not mandatory, as long as you don't have multiple versions of the same bundle in the repository folder(s).
GianMaria.
Edited: rephrased a sentence to make it easier to understand.
[Updated on: Wed, 27 July 2016 11:51] by Moderator
Re: Plan with CXF DOSGi 3.1.6 fails to start [message #1739135 is a reply to message #1739129] Wed, 27 July 2016 12:02 Go to previous messageGo to next message
Perfect! It was the bundle symbolic name that was causing the problem.
I've had to change all of the short names to the fully qualified symbolic names it the plan is now "ACTIVE".
Thanks!
Re: Plan with CXF DOSGi 3.1.6 fails to start [message #1739198 is a reply to message #1739125] Thu, 28 July 2016 05:40 Go to previous messageGo to next message
The plan starts and all the defined bundles are resolved and running.
I haven't included CXF's jetty bundle as I don't want that starting up. I have configured SPNEGO single sign on in Virgo's tomcat and I don't want to have to manage 2 web servers.
I registered a service whose interface is annotated with the javax.jws annotations.
And in the props I have also added the following values:
service.exported.interfaces = my.interface.Name
service.exported.configs = org.apache.cxf.ws
context.registerService( my.interface.Name.class, myImpl, props );
Everything works but I must still be missing something.
It doesn't look like CXF registers itself with tomcat as a servlet and I don't see anything in the logs that would point to anything in that direction.
Can some kind soul point me in the right direction please?
Re: Plan with CXF DOSGi 3.1.6 fails to start [message #1739211 is a reply to message #1739198] Thu, 28 July 2016 07:11 Go to previous message
Here is what I get in the logs, I think that it looks all right: https://gist.github.com/anonymous/0196f200e326612ad1b701555218fc9e
Previous Topic:Active production installations?
Next Topic:How to Take Thread Dumps on Virgo-Jetty Server
Current Time: Tue Sep 16 00:33:12 EDT 2025
Powered by FUDForum. Page generated in 0.07993 seconds
