Home » Modeling » TMF (Xtext) » ImportNamespace scoping problem(ImportNamespace scoping does not work with qualifiedNameWithWildcard)
ImportNamespace scoping problem [message #1739037] Wed, 27 July 2016 02:55 Go to next message
Hi guys!
Almost as in the 15 Minutes Tutorial I created a grammar for my DSL. As you can see, I used the EMF for modeling the meta-model.
If I declare an import like the code in the following lines, the scope works, but I can't use a wildcard-import (anyPkg.*):
Import:
	'Import' importedNamespace = [TypeLibrary|QualifiedName] ';';
by the way I understand why the wildcard import won't work Laughing
In opposit to the last declaration, the scope does not work in the following declaration, but the wildcard-import does:
Import:
	'Import' importedNamespace = QualifiedNameWithWildcard ';';
Well, this is my code example where the problem exists:
generate domainModel "DomainModel"
domainModel:
	(elements += Import)*
	elements += TypeLibrary
Import:
TypeLibrary returns TypeLibrary:
	'TypeLibrary' name = QualifiedName
		(elements += (Type1|Type2|Type3))*
// (Type rules)
And now my target is to make it possible to import types as well as packages with the functionality of scoping. I'm very sorry if I misunderstood the tutorial but I just started working with this awesome plugin.
So I'd be very happy when you could help me or give me a hint how i can solve the problem or find a solution fitting to it.
Thank you for dealing with my problem!
Re: ImportNamespace scoping problem [message #1739116 is a reply to message #1739037] Wed, 27 July 2016 11:09 Go to previous messageGo to next message
can you share your complete grammar and test model
Re: ImportNamespace scoping problem [message #1739408 is a reply to message #1739116] Mon, 01 August 2016 01:42 Go to previous messageGo to next message
Sorry for the delay.
I attached my project folders. Well, the model of my main project has to be protected, because it concerns safety-critical infrastructure.
So I created another example project where the problem is the same. Don't mind about the strange package/class identifiers, I just did this quickly.
The problem once again in a short version:
importedNamespace = [TypeLibrary|QualifiedName]:
The editor provides a Scope with all packages.
importedNamespace = QualifiedName(withWildcard):
I can import packages but there is no scope provided.
If the combination is not possible, I would be very happy if somebody could give me a reference showing how to work arround this problem.
Thank you!
Re: ImportNamespace scoping problem [message #1739411 is a reply to message #1739408] Mon, 01 August 2016 02:37 Go to previous messageGo to next message
sry importedNamespace = QualifiedNameWithWildcard works for me.
what do you mean by code provided?
scope for the import?
if you want importedNamespace = [TypeLibrary|QualifiedName]:
you have to adapt
org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.internalGetImportedNamespaceResolvers(EObject, boolean)
and use nodemodelutils to retrieve the text.
and create a wildcard import for that text
Re: ImportNamespace scoping problem [message #1739415 is a reply to message #1739411] Mon, 01 August 2016 03:43 Go to previous messageGo to next message
Using importedNamespace = [TypeLibrary|QualifiedName] was just a work around for me.
When I use importedNamespace = QualifiedNameWithWildcard, i can import packages as well classes BUT if I write import I don't get all possibile imports listed.
The project I am working on has a high variety of packages and classes so such a list is very important.
So what I want is an appearance in editor like this when I start typing a library name:
Import M...
|MainLib.SubLib1...................|
|MainLib.SubLib2...................|
|MainLib.SubLib2.SubClass..|
And I currently just get this appearance (without classes) by using importedNamespace = [TypeLibrary|QualifiedName].
Finally, I also want to import classes, not only packages.
Re: ImportNamespace scoping problem [message #1739417 is a reply to message #1739415] Mon, 01 August 2016 04:08 Go to previous message
i cannot follow you on this. you have to implement that yourself. i gave you some hints how to deal with
Previous Topic:JvmTypeReference isAssignable
Next Topic:XText netbeans support
Current Time: Mon Jul 21 00:31:26 EDT 2025
Powered by FUDForum. Page generated in 0.03450 seconds
