Home » Modeling » EMF » Unique ID's for each Type/Class, with references
Unique ID's for each Type/Class, with references [message #1739047] |
Wed, 27 July 2016 04:33  |
I am trying to make en Ecore-model generated from an xsd. This xsd contains ID-like attributes, and references from one element to another element which need to be resolved based on these ID's. So far, I am using 'ecore:id' and 'ecore:reference' attributes, this works as expected.
However, there are multiple types defined that have an ID, and the ID is unique for each type, not unique for all types. For instance, there can be a Node with id '1' and a Edge with an id '1'. This is not supported by EMF out of the box. Is there a way to allow unique ID's for each type, and resolve references based on these ID's?
Kind Regards,
Rolf
Re: Unique ID's for each Type/Class, with references [message #1739067 is a reply to message #1739047] |
Wed, 27 July 2016 06:15   |
Rolf,
No immediate obvious way to achieve that comes to mind. It if maps to
an EAttribute with iD true, the resource will validate as invalid when
there is more than one object with that ID, so even that's already a
problem.
On 27.07.2016 10:33, Rolf Theunissen wrote:
> expected.
> Kind Regards,
> Rolf
Re: Unique ID's for each Type/Class, with references [message #1739425 is a reply to message #1739106] |
Mon, 01 August 2016 04:42   |
I managed to get it working, by dropping the usage of ID's, and tweaking the serialization/deserialization of the XMLResourceImpl together with custom getEObjectByID logic, see below.
It seems a bit strange to me that the deserialization from a string reference to an custom 'URI-fragment' must be implemented in the XMLHandler, while the serialization from a reference to a string can be implemented in the XMLHelper. I would have expected an method in the XMLHelper which would be called for the conversion from string to URI-fragment/ID, or I misunderstood the API.
Kind regards,
Rolf
public class GexfResourceImpl extends XMLResourceImpl {
protected Map<String, EObject> idToNodeContentMap = new HashMap<String, EObject>();;
protected Map<String, EObject> idToEdgeContentMap = new HashMap<String, EObject>();;
* Creates an instance of the resource.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @param uri
* the URI of the new resource.
* @generated
public GexfResourceImpl(URI uri) {
super(uri);
protected EObject getEObjectByID(String id) {
if (id.charAt(0) == '[') {
int index = id.indexOf('=');
if (index > 0) {
String type = id.substring(1, index);
String tid = id.substring(index + 1, id.length() - 1);
if (type.equals("node")) {
EObject eObject = idToNodeContentMap.get(tid);
if (eObject != null) {
return eObject;
EObject result = null;
for (TreeIterator<EObject> i = getAllProperContents(getContents()); i.hasNext();) {
eObject = i.next();
if (eObject instanceof NodeContent) {
String nodeId = ((NodeContent) eObject).getId().toString();
if (nodeId != null) {
// TODO make robust for changed Id-values in NodeContent; Add notification listener?
idToNodeContentMap.put(nodeId, eObject);
if (result == null && nodeId.equals(tid)) {
result = eObject;
return result;
} else if (type.equals("edge")) {
EObject eObject = idToEdgeContentMap.get(tid);
return eObject;
eObject = i.next();
if (eObject instanceof EdgeContent) {
String edgeId = ((EdgeContent) eObject).getId().toString();
if (edgeId != null) {
// TODO make robust for changed Id-values in EdgeContent; Add notification listener?
idToEdgeContentMap.put(edgeId, eObject);
if (result == null && edgeId.equals(tid)) {
result = eObject;
return super.getEObjectByID(id);
protected XMLHelper createXMLHelper() {
return new XMLHelperImpl(this) {
public String getHREF(EObject obj) {
if (obj instanceof NodeContent) {
return ((NodeContent) obj).getId().toString();
} else if (obj instanceof EdgeContent) {
return ((EdgeContent) obj).getId().toString();
return super.getHREF(obj);
protected XMLLoad createXMLLoad() {
return new XMLLoadImpl(createXMLHelper()) {
protected DefaultHandler makeDefaultHandler() {
return new SAXXMLHandler(resource, helper, options) {
protected void setValueFromId(EObject object, EReference eReference, String ids) {
if (eReference.getEReferenceType() == GexfPackage.Literals.NODE_CONTENT) {
ids = "[node=" + ids + ']';
} else if (eReference.getEReferenceType() == GexfPackage.Literals.EDGE_CONTENT) {
ids = "[edge=" + ids + ']';
super.setValueFromId(object, eReference, ids);
Re: Unique ID's for each Type/Class, with references [message #1739747 is a reply to message #1739425] |
Mon, 01 August 2016 05:24  |
Rolf,
What can I say? That "API" has a 17 year history behind it and has
"evolved" so many times (with binary compatibility even for protected
methods and field being necessary) that it's just not pretty (and never
really was).
> Kind regards,
> Rolf
> * Creates an instance of the resource. * <!-- begin-user-doc
> --> * <!-- end-user-doc -->
> * * @param uri
> * @generated
> super(uri);
> @Override
> if (index > 0) {
> return eObject;
> eObject = i.next();
> result = eObject;
> return result;
> return eObject;
> eObject = i.next();
> result = eObject;
> @Override
> @Override
> @Override
> @Override
> @Override
Re: Unique ID's for each Type/Class, with references [message #1741967 is a reply to message #1739106] |
Kind regards,
Rolf
* @param uri
* @generated
super(uri);
if (index > 0) {
return eObject;
eObject = i.next();
result = eObject;
return result;
return eObject;
eObject = i.next();
result = eObject;
Re: Unique ID's for each Type/Class, with references [message #1741969 is a reply to message #1741967] |
Rolf,
really was).
> Kind regards,
> Rolf
> * * @param uri
> * @generated
> super(uri);
> @Override
> if (index > 0) {
> return eObject;
> eObject = i.next();
> result = eObject;
> return result;
> return eObject;
> eObject = i.next();
> result = eObject;
> @Override
> @Override
> @Override
> @Override
> @Override
Current Time: Sun Jul 27 04:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.05907 seconds
