Home » Modeling » EMF » Improve XMLResourceImpl's URI Fragments upon serialization
Improve XMLResourceImpl's URI Fragments upon serialization [message #1739063] Wed, 27 July 2016 05:33 Go to next message
For our internal needs, we upgraded our resource implementation to change how references are generated / read upon (de)serialization.
In our model, we have ids only on specific elements and not on the element contained into the said elements. But we also have a lot of references toward contained elements (and therefore without ids).
The "issue" we had was that the XMLResource generates references like:
"<resource>#<fragment uri>"
Where <fragment uri> is either <id> or <xpath-like>.
So we ended up with a lot of references looking like:
"<parent href="file.ext#//@elm1.0/@positions.1/@item.0/@description"/>"
Which is kind of lame because "//@elm1.0/@positions.1/@item.0" is an element with an id.
So, to make the long story short, we changed the generation to generate:
"<parent href="file.ext#<item id>/@description"/>"
Basically, it looks into the container of the element, looks for the closest id, and starts the xpath from the element prefixing by its id. (and if no element have an id, the full xpath is generated)
All this explanation just to ask you: do you think it is worth contributing our change to the XMLResourceImpl? (I mean to make a ticket, a pull request and so on)
Michael.
Re: Improve XMLResourceImpl's URI Fragments upon serialization [message #1739068 is a reply to message #1739063] Wed, 27 July 2016 06:17 Go to previous messageGo to next message
That sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=494506 right?
On 27.07.2016 11:33, Michael Longo wrote:
> element with an id.
> Michael.
Re: Improve XMLResourceImpl's URI Fragments upon serialization [message #1739069 is a reply to message #1739068] Wed, 27 July 2016 06:18 Go to previous messageGo to next message
And it does sound useful. There are cases in Oomph where this would
help prevent errors when people textually merge the serialized setup
instances...
> right?
>> Hi,
>> element with an id.
>> Thanks,
>> Michael.
Re: Improve XMLResourceImpl's URI Fragments upon serialization [message #1739085 is a reply to message #1739068] Wed, 27 July 2016 09:22 Go to previous message
It sure does sound like that Smile
I looked into it a couple of month ago and hadn't seen anything related!
But yes, it the same principle with slightly different implementation. I'll add as attachment to the ticket our implementation, and I'll leave into your hand to do whatever you want with it! Smile
But in the ticket you are right: it should come as an optional feature to not break the compatibility between newly generated files and older programs. A save option might be a good way to do it.
Previous Topic:Neon: UpdateStrategy logs ERROR when binding Double to Text
Next Topic:Xtext based cell editor in EMF
Current Time: Sun Jul 27 06:42:16 EDT 2025
Powered by FUDForum. Page generated in 0.04228 seconds
