Home » Modeling » EMF » CDO and Walking EMF(How does CDO walk and EMF model)
CDO and Walking EMF [message #1738611] Thu, 21 July 2016 08:06 Go to next message
All,
I am digging through the CDO codebase and no doubt, in time, will find what I am looking for; but if someone would be so good as to speed me on my way I would appreciate it.
Somewhere CDO must walk through an EMF in order to persist it. I assume it does this with a common, consistent routine that is shared by all. How can I take advantage of that? Apologies in advance if I've missed the documentation on this.
I need to persist EMF in other ways than are supported, hence my interest. I've seen this walking done in other (not CDO) projects and even wrote a rudimentary one myself. But I'll bet the CDO project has a nice robust implementation somewhere.
Re: CDO and Walking EMF [message #1738617 is a reply to message #1738611] Thu, 21 July 2016 08:40 Go to previous messageGo to next message
Am 21.07.2016 um 15:06 schrieb Geoffry Roberts:
> All,
Sorry, it's really not clear to me what your looking for. Maybe you can rephrase your desire more concisely?
If by "walk through an EMF" you mean to traverse a model (sub) tree, you could use the TreeIterator tat is returned from
the eAllContents() method of the root object of that (sub) tree.
Cheers
/Eike
http://www.esc-net.de
> somewhere.
> Thanks
Re: CDO and Walking EMF [message #1738765 is a reply to message #1738617] Sat, 23 July 2016 09:52 Go to previous messageGo to next message
You make good points. We don't always realize when we're not being clear.
Let me go at it this way, I want to persist EMF in ways that are not currently implemented. I can of course roll my own and have done so in the past, but I think it would be better if this were done in harmony with the CDO framework. So let me ask a variant of one of the FAQs: Can we change the underlying data base to use something like <My favorite DB> instead of relational DB? and if so, can you help me get started?
I've been looking through the code for the MongoDB persistence thinking it is the most similar to what I want to do. I have yet to discover how EMF and DBObject go together. It's slow going.
Re: CDO and Walking EMF [message #1738780 is a reply to message #1738765] Sun, 24 July 2016 01:44 Go to previous message
Am 23.07.2016 um 16:52 schrieb Geoffry Roberts:
Yes, that's possible by implementing org.eclipse.emf.cdo.spi.server.InternalStore, or better by extending
org.eclipse.emf.cdo.spi.server.Store or org.eclipse.emf.cdo.spi.server.LongIDStore.
You'll also have to create your custom implementation of org.eclipse.emf.cdo.server.IStoreAccessor, for example by
extending org.eclipse.emf.cdo.spi.server.StoreAccessorBase, org.eclipse.emf.cdo.spi.server.StoreAccessor, or
org.eclipse.emf.cdo.spi.server.LongIDStoreAccessor.
Beware that there's no good extender documentation, but there are quite a few examples in our code base. The
DBStore(Accessor) is the most complete store implementation.
Our MongoDBStore is very different from all the other store implementations, because MongoDB does not support
transactions with ACID properties. I.e., we can't atomically persist multiple documents for the changed EMF objects. We
rather atomically persist the commit change set as one document. Hence the MongoDBStore is a "delta store" with very
fast writing and slower reading (depending on the history that needs to be queried for each read).
I'm not sure I heard of DBObject.
Cheers
/Eike
Previous Topic:Skipping resolution error when loading
Next Topic:How to suppress target namespace generation on xml resource serialization
Current Time: Wed Jul 23 21:41:24 EDT 2025
Powered by FUDForum. Page generated in 0.19535 seconds
