Home » Modeling » TMF (Xtext) » Serialize cross-reference in stand-alone mode
Serialize cross-reference in stand-alone mode [message #1738402] Tue, 19 July 2016 09:10 Go to next message
I am experiencing problems when serializing a cross-reference when using Xtext in a stand-alone context.
Below is a sample program that reproduces the serialization problem.
	@Test
	public void testCrossReferencing() {
                ResourceSet resourceSet = new XtextResourceSet();
		DomainModel dm = XXXFactory.eINSTANCE.createDomainModel();
		dm.setName("TypesModel");
		Type t = XXXFactory.eINSTANCE.createType();
		t.setName("Integer");
		dm.getElements().add(t);
		URI uri1 = URI.createPlatformResourceURI("sample.tests/models/tmp/TypesModel.hddd");
		Resource rs1 = resourceSet.createResource(uri1);
		rs1.getContents().add(dm);
		TypedElement te = XXXFactory.eINSTANCE.createTypedElement();
		te.setType(t);
		te.setName("attr");
		ValueObject vo = XXXFactory.eINSTANCE.createValueObject();
		vo.setName("VO1");
		vo.getAttributes().add(te);
		DomainModel dm2 = XXXFactory.eINSTANCE.createDomainModel();
		dm2.setName("DataModel");
		dm2.getElements().add(vo);
		URI uri2 = URI.createPlatformResourceURI("sample.tests/models/tmp/DataModel.hddd");
		Resource rs2 = resourceSet.createResource(uri2);
		rs2.getContents().add(dm2);
		try {
			rs1.save(Collections.EMPTY_MAP);
			rs2.save(Collections.EMPTY_MAP);
		} catch (IOException e) {
			e.printStackTrace();
rs2 contains a cross-reference from the TypedElement object to a TypeObject in rs1 via the type reference. The resulting stack trace upon saving rs2 is the following:
java.lang.RuntimeException: No EObjectDescription could be found in Scope TypedElement.type for DomainModel'TypesModel'.elements[0]->Type'Integer'
Semantic Object: DomainModel'DataModel'.elements[0]->ValueObject'VO1'.attributes[0]->TypedElement'attr'
	at org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:77)
	at
I have debugged the code up until the point that I could indeed verify that the scope is empty. No candidates exist to resolve the cross-reference.
From loading Xtext resources, I know that cross-references are only resolved when all resources are contained by the XtextResourceSet, so I expected something similar when adding and saving resources.
However, this doesn't seem to be the case. My question therefore is: how to update the index when adding new resources to the resourceset, such that the cross-references get resolved upon serialization of cross-references in Xtext resources?
Re: Serialize cross-reference in stand-alone mode [message #1738411 is a reply to message #1738402] Tue, 19 July 2016 09:58 Go to previous messageGo to next message
Can you share a min reproducing example
Re: Serialize cross-reference in stand-alone mode [message #1738425 is a reply to message #1738411] Tue, 19 July 2016 12:12 Go to previous messageGo to next message
btw createPlatformResourceURI does not sound very standalone
Re: Serialize cross-reference in stand-alone mode [message #1738427 is a reply to message #1738425] Tue, 19 July 2016 12:48 Go to previous messageGo to next message
On the contrary, if you make sure you have a well-configured
URIMap/URIHandler, createPlatformResourceURI is very desirable for
standalone usage. The same code can be used standalone or within Eclipse
without chnage.
Ed Willink
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Re: Serialize cross-reference in stand-alone mode [message #1738454 is a reply to message #1738427] Wed, 20 July 2016 01:16 Go to previous messageGo to next message
yes. this is why i asked for a reproducable example. with a handmade one i cannot reproduce in standalone, but in eclipse for sure.
Re: Serialize cross-reference in stand-alone mode [message #1738500 is a reply to message #1738454] Wed, 20 July 2016 07:16 Go to previous messageGo to next message
Thanks for your replies. The discussion the two of you had triggered me to perform a small experiment where the platform URI is replaced with a file URI. To my surprise, both resources, also the one that contains the cross-reference, were correctly serialized to disk. Great!
Question remains: why was the absolute file URI required for the Xtext index/scoping mechanism to properly resolve the cross-reference during serialization?
Btw. I tried to extend the URIMap of the URIConverter attached to the resourceSet with an entry to map the platform URI onto the file URI:
	URI srcURI = URI.createPlatformResourceURI("sample.tests/");
	URI trgtURI = URI.createFileURI("C:/myworkspace/sample.tests/");
	resourceSet.getURIConverter().getURIMap().put(srcURI, trgtURI);
Somehow, normalization takes no effect so the platform URI from the example is not automatically translated into the physical URI. When I print the string representation of the normalized URI, the file URI is however correct:
	URI uri1 = URI.createURI("platform:/resource/sample.tests/models/tmp/TypesModel.hddd");
	System.out.println(resourceSet.getURIConverter().normalize(uri1).toString());
Console shows output:
file:/C:/myworkspace/sample.tests/tmp/TypesModel.hddd
Any thoughts on this?
Re: Serialize cross-reference in stand-alone mode [message #1738502 is a reply to message #1738500] Wed, 20 July 2016 07:26 Go to previous messageGo to next message
This ensures searialized models can be reparsed / the model you serialize
fulfills your scoping rules
Re: Serialize cross-reference in stand-alone mode [message #1738516 is a reply to message #1738502] Wed, 20 July 2016 09:37 Go to previous messageGo to next message
Again, thanks for your reply. It still leaves me a bit puzzled to be honest. Can you please elaborate more on the answer to my question? Apparently it's required for the Xtext global scope to be build with resources for which it holds that they can be properly referenced by a absolute file URI. Why is that the case?
Re: Serialize cross-reference in stand-alone mode [message #1738536 is a reply to message #1738516] Wed, 20 July 2016 11:43 Go to previous messageGo to next message
I dont get that Part of the question. In standalone mode the global scope
is the sum of all resources in the resourceset but what about your
customization to the scope
Re: Serialize cross-reference in stand-alone mode [message #1738557 is a reply to message #1738402] Wed, 20 July 2016 16:15 Go to previous messageGo to next message
The question is why the cross-reference serialization fails when using platform resource URIs (possibly that cannot be properly normalized), but succeeds when using file URIs?
I am not aware of any customizations I made to the global scope, however it could well be the case that I selected a different scope strategy in the MWE2 workflow to allow resolution of cross-references based on fully qualified names.
Re: Serialize cross-reference in stand-alone mode [message #1738558 is a reply to message #1738557] Wed, 20 July 2016 16:32 Go to previous message
Can you please Share a complete example
Previous Topic:[SOLVED] XtextBuilder issue with a created project from existing model
Next Topic:Xtext/Xtend in C Language
Current Time: Mon Sep 15 19:38:16 EDT 2025
Powered by FUDForum. Page generated in 0.22499 seconds
