Home » Eclipse Projects » Eclipse Scout » [neon] Build custom UI element
[neon] Build custom UI element [message #1738023] Fri, 15 July 2016 03:19 Go to next message
Hello everyone
First of all - awesome new scout release, thanks for sharing!
We want to build some custom UI elements, e.g. a tag field where multiple tags can be entered - like a smartfield where n items can be selected and are represented as tags.
Since the current documentation doesn't mention this topic, I browsed through the org.eclipse.scout.rt.client-6.0.0.M6_1-sources.jar where controls are obviously implemented.
Therefore my question is:
What is the recommended way to extend the existing control set of scout in order to keep updatability ?
Thanks for your effort and best regards
Kevin
[Updated on: Fri, 15 July 2016 03:38] by Moderator
Re: [neon] Build custom UI element [message #1738545 is a reply to message #1738023] Wed, 20 July 2016 13:49 Go to previous messageGo to next message
Hi Kevin
Your tag field sounds cool! If you want to keep things simple, you could build such an element with existing fields only (e.g. an abstract group box that contains a table and a smartfield). This would be 100% safe when updating the Scout release (okay, maybe 99% Wink ). You can even add custom CSS rules to such a field template (using the getConfiguredCssClass() property). But be aware that the CSS is not guaranteed to be stable across Scout versions. However, it should not be very hard to fix a broken CSS on version change.
A completely new widget requires several parts:
  • The Scout client model for the new field (*.client module --> AbstractMyField.java)
  • The adapter that translates data and events from the model format (Java object) to the UI format (JSON). (*.ui.html module --> JsonMyField.java)
  • The javascript part that runs in the browser and renders the received JSON data to HTML and vice versa. (*.ui.html module --> MyField.js)
I don't know if there is already a full documentation available on that topic, but maybe it already helps if you have a look at the completely custom "HeatMapField" in the widgets demo application:
Demo: https://scout.bsi-software.com/widgets/?dl=widget-heatmapfield
Source: https://github.com/BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs/tree/releases/6.0.x/code/widgets
This approach is very flexible, but is more likely to break when updating Scout, especially the JavaScript and CSS part (because there is no Java-equaivalent support for APIs in those languages). My advice would be to keep things as simple as possible to reduce the amount of code that can break. Wink
Beat
Re: [neon] Build custom UI element [message #1738662 is a reply to message #1738545] Thu, 21 July 2016 17:56 Go to previous message
Hi Beat
Thanks for your detailed reply.
We will go for a new widget, therefore the description of a widget's structure is really helpful!
Also thanks for mentioning the heat field, this is a perfect reference.
Kevin
Previous Topic:Display icon on SmartColumn
Next Topic:AbstractPageWithNodes with default page
Current Time: Sun Jul 20 20:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
