Home » Modeling » TMF (Xtext) » [SOLVED] XtextBuilder issue with a created project from existing model
[SOLVED] XtextBuilder issue with a created project from existing model [message #1737723] Tue, 12 July 2016 05:02 Go to next message
Hello everyone,
I have created a new Xtext project from an existing model with the extension "cf_app".
I have created also a generator for this model by using xtend, but this generator is never started when I edit a cf_app model in runtime.
When debugging I see that org.eclipse.xtext.resource.IResourceServiceProvider.Registry.getExtensionToFactoryMap() doesn't contain the extension of my model "cf_app".
My language configuration :
language = StandardLanguage {
			name = "..."
			fileExtensions = "cf_app"
			referencedResource = "platform:/resource/...model/cofluent.genmodel"
			fragment = ecore2xtext.Ecore2XtextValueConverterServiceFragment2 auto-inject {}
			fragment = org.eclipse.xtext.generator.adapter.FragmentAdapter {
				fragment = org.eclipse.xtext.generator.ecore2xtext.FormatterFragment {}
			serializer = {
				generateStub = false
			// generator API
			fragment = generator.GeneratorFragment2 {
				generateJavaMain = true
FYI: I have no compilation errors.
[Updated on: Fri, 29 July 2016 04:43] by Moderator
Re: XtextBuilder issue with a created project from existing model [message #1737778 is a reply to message #1737723] Tue, 12 July 2016 15:54 Go to previous messageGo to next message
This is generally hard to answer?
Did you check for warnings is development eclipse ( specially on build.properties and plugin.xml)
Did you check host Osgi console if the yourdsl.ui plugin is properly activated.
Did you change the file extension in the workflow?
Does the log contain anything?
Re: XtextBuilder issue with a created project from existing model [message #1737839 is a reply to message #1737778] Wed, 13 July 2016 08:37 Go to previous messageGo to next message
Hi Christian,
mydsl.ui plugin is loaded and I haven't errors (or warning in manifests, plugin.xml or properties files). The erro log contains nothing also.
After debugging, I see the "cf_app" extension in the Registry when the resource is open for the first time (runtime startup). But after editing the resource, the extension "cf_app" doesn't appear in the registry.
Re: XtextBuilder issue with a created project from existing model [message #1737840 is a reply to message #1737839] Wed, 13 July 2016 08:42 Go to previous messageGo to next message
do you have any customizations? e.g. what did you implement in your generator?
can you share a complete small example?
Re: XtextBuilder issue with a created project from existing model [message #1738038 is a reply to message #1737840] Fri, 15 July 2016 05:50 Go to previous messageGo to next message
In my configuration I had the error "Problem during instantiation of org.eclipse.xtend.lib.annotations.FinalFieldsConstructorProcessor" in MydslUiModule classe when using @FinalFieldsConstructor annotation, this is why I created manually my constroctor.
Re: XtextBuilder issue with a created project from existing model [message #1738528 is a reply to message #1738038] Wed, 20 July 2016 10:40 Go to previous message
The problem was in my launch config, I set the Program to run variable to "org.eclipse.sdk.ide" instead another product and it works fine.
Thank you.
Previous Topic:referencing existing ecore-model from xtext
Next Topic:Serialize cross-reference in stand-alone mode
Current Time: Mon Jul 21 01:22:22 EDT 2025
Powered by FUDForum. Page generated in 0.11915 seconds
