Home » Modeling » TMF (Xtext) » referencing existing ecore-model from xtext(Problems with referencing classes of ecore-model from dsl)
referencing existing ecore-model from xtext [message #1738439] Tue, 19 July 2016 16:40 Go to next message
Hello. I am using xtext 2.10. I created an EMF project with library.ecore model. The model consists of Library, Book and Author. Also I created xtext project org.xtext.example.mydsl which should use this ecore model. The grammar of my language:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate  "http://www.xtext.org/example/mydsl/MyDsl"
import "platform:/resource/org.example.library/model/library.ecore" as librarymodel
import "http://www.eclipse.org/emf/2002/Ecore"
Model:
	books+=MyBook*;
FullyQualifiedName:
	ID ("." ID)*;
MyBook:
	'book' book = [librarymodel::Book|FullyQualifiedName]
I included library.genmodel as a referencedResource in my GenerateMyDsl.mwe2 :
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.xtext.example.mydsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "windows-1251"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "org.xtext.example.mydsl.MyDsl"
			referencedResource = "platform:/resource/org.example.library/model/library.genmodel"
			fileExtensions = "mydsl"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
After that I run a runtime application and create an instance of my library ecore model with several books and authors: mylibrary.library. I also created file test.mydsl and I would like to reference books from mylibrary.library. However, the content assist is empty and mylibrary-objects are not referenceable.
What am I missing? How can I reference objects of ecore-model-instances from mydsl file.
[Updated on: Tue, 19 July 2016 16:43] by Moderator
Re: referencing existing ecore-model from xtext [message #1738440 is a reply to message #1738439] Tue, 19 July 2016 16:46 Go to previous message
If you want to reference non xtext models from xtext you need to provide a
I resourceserviceprovider for that. An example describing the idea can be
found here
https://christiandietrich.wordpress.com/2011/07/17/xtext-2-0-and-uml/
Previous Topic:Problem with ecore and the new generator
Next Topic:[SOLVED] XtextBuilder issue with a created project from existing model
Current Time: Sun Jul 20 20:53:03 EDT 2025
Powered by FUDForum. Page generated in 0.04768 seconds
