Home » Modeling » Epsilon » Splitting ETL into several modules
Splitting ETL into several modules [message #1738264] Mon, 18 July 2016 10:08 Go to next message
my ETL consists of different logical parts, some of this parts (ETL) beeing generated. Presviously, I had everything into one *.etl transformation file and everything worked.
When I split my etl into several etl's and integrated them with the import statement, i got many runtime errors.
There seems be some limitations here, but I couldn't found any hints in the epsilon book.
I thought that any etl can define its own pre block, but the pre block in the imported etl's is not interpreted.
My primary motivation for spliting the ETL is to separate generated from "hand coded" ETL code. I know that epsilon has a template & merge engine, but after ETL & Validation i didn't want to jump again into a new topic. That's why, the generation of ETL is plain old java code (for the moment).
What would be the best approach to my problem.
Christian
[Updated on: Mon, 18 July 2016 10:12] by Moderator
Re: Splitting ETL into several modules [message #1738355 is a reply to message #1738264] Tue, 19 July 2016 05:13 Go to previous messageGo to next message
Hi Christian,
Splitting ETL transformations over multiple files shouldn't be a problem at all. Off the top of my head, my guess is that your rules implicitly rely on a particular execution order (e.g. common if you're querying the target model), and splitting your transformation across different files has changed this order.
Dimitris
Re: Splitting ETL into several modules [message #1738408 is a reply to message #1738355] Tue, 19 July 2016 09:35 Go to previous message
yes, you have right. Due to the execution order of the rules, my ETL has a different behaviour when using imports or not.
Within a module, the rules are executed in the same order as they are defined in the ETL, right.
When importing moduleB in moduleA, what would be the execution order?
All rules from moduleB and then all rules from moduleA.
I have to re-organize my imports, this should help.
Btw, today i discovered the extended properties by change. Really cool feature! I modified my etl and got rid of plenty of maps...
Regards from Germany,
Christian
Previous Topic:Performance of Epsilon Validation
Next Topic:There is a selectFirst method on ETL?
Current Time: Wed Jul 23 16:55:55 EDT 2025
Powered by FUDForum. Page generated in 0.07401 seconds
