Home » Modeling » EMF » [Xcore] Default value of a DataType
[Xcore] Default value of a DataType [message #1738190] Sun, 17 July 2016 19:11 Go to next message
I'm trying to set the default value of a wrapped class (I want to avoid the default null value). A little example :
class PositionObject
	PointF position = "1;2" // new Vector2f(1, 2)
type PointF wraps Vector2f
create
	if(it != null)
		val String[] split = it.split(";")
		if(split.length == 2)
			new Vector2f(Float.valueOf(split.get(0)), Float.valueOf(split.get(1)))
	new Vector2f
convert
	it.x + ";" + it.y
Unfortunately, Xcore doesn't allows the PointF position = "1;2" (the error message : "The default value literal '1;2' must be a valid literal of the attribute's type").
But : if I remove the create and convert parts, the error message disappears (but the generated code no longer knows how to parse my string Sad ).
Did I missed something ?
If I can't do that, how can I just set a default value like PointF position = new Vector2f() ?
[Updated on: Mon, 18 July 2016 05:15] by Moderator
Re: [Xcore] [message #1738240 is a reply to message #1738190] Mon, 18 July 2016 06:46 Go to previous messageGo to next message
Where is Vector2f defined/implemented?
Looking at the logic in
org.eclipse.emf.ecore.util.EcoreValidator.validateEStructuralFeature_ValidDefaultValueLiteral(EStructuralFeature,
DiagnosticChain, Map<Object, Object>) there's code like this:
// If there is a conversion delegate then the lack of a
default value really does indicate that there is a problem converting
the literal to a value.
EDataType.Internal.ConversionDelegate conversionDelegate =
((EDataType.Internal)eDataType).getConversionDelegate();
if (conversionDelegate != null)
And Xcore does set the conversion delegate, which needs to be able to
run your code. That happens in
org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EDataType, String)
return conversionDelegate.createFromString(stringValue);
Perhaps this isn't working because the class can't be loaded. So I
wonder is the class in that project, or is it from some library in
another project, or what?
On 18.07.2016 01:11, ealrann xor wrote:
> Hello,
> type PointF wraps Vector2f create
> if(it != null)
> new Vector2f
> convert
> it.x + ";" + it.y
> Unfortunately, Xcore doesn't allow the PointF position = "1;2" (the
> But : if I remove the create and convert part, the error message
> string :( ).
Re: [Xcore] [message #1738244 is a reply to message #1738240] Mon, 18 July 2016 07:10 Go to previous messageGo to next message
Thanks for the fast reply.
The Vector2f is on the same project :
http://tof.canardpc.com/view/0ea51e25-83b2-41fd-8c99-5a110d8d35cf.jpg
http://tof.canardpc.com/view/4584152f-1834-4063-a09c-7b388c2ac2a1.jpg
When I remove the create and convert, no more errors :
http://tof.canardpc.com/view/67c9a6d2-0432-4d9f-965e-2fe25a669e08.jpg
[Updated on: Mon, 18 July 2016 07:16] by Moderator
Re: [Xcore] [message #1738270 is a reply to message #1738244] Mon, 18 July 2016 10:33 Go to previous messageGo to next message
The attached project in which I try to reproduce your problem works for
me in my development environment. It shows an error only if the literal
isn't well formed...
Re: [Xcore] [message #1738272 is a reply to message #1738270] Mon, 18 July 2016 11:08 Go to previous messageGo to next message
That's really weird.
I'm not at home and I don't have my development environment, so I imported your project on a Eclipse EMF Mars : the problem is still here :
http://img11.hostingpics.net/pics/201925problem.jpg
A clean does not resolve the error. But, the code is well generated (that is not the case on my Project).
I'll try deeply when I'd back to home.
[Updated on: Mon, 18 July 2016 11:08] by Moderator
Re: [Xcore] [message #1738278 is a reply to message #1738272] Mon, 18 July 2016 11:18 Go to previous messageGo to next message
I'm using the Neon version. Perhaps something has been fixed in the
latest year.
Re: [Xcore] [message #1738293 is a reply to message #1738278] Mon, 18 July 2016 13:26 Go to previous messageGo to next message
Better with Neon, but I still have the error :
At first look, your sample project is working on Neon, but the error still appears when you clean the project. At this time, the only way to remove the error is to edit the .xcore and save it.
I tried with a clean install of Neon EMF (windows x64), with xcore from update site.
Re: [Xcore] [message #1738298 is a reply to message #1738293] Mon, 18 July 2016 14:53 Go to previous messageGo to next message
Yes, I noticed that too. Feel free to open a Bugzilla for that. There's
already a bugzilla about cyclic rebuilds. In this case, it seems as if
two builds are really needed because until the class wrapped by the data
type is built, it can't be loaded and resolved by the Xcore model. It
sounds like a tricky problem for sure...
> from update site.
Re: [Xcore] [message #1738424 is a reply to message #1738298] Tue, 19 July 2016 12:08 Go to previous message
Ok, about the clean problem : I have opened a Bugzilla : https://bugs.eclipse.org/bugs/show_bug.cgi?id=498138
And finally : about my default value problem :
The error was systematic on my project : I was never able to set a default value, but I finally figured out why : I use BNDTools in my projects, and it seems to interrupt the xcore generation (something like this). So the EDatatype default value was always in error.
I finally solve it by editing the nature of the eclipse project, to prioritize the XText nature over the BNDTools nature.
Thank you for your help (and thank you for EMF Smile )
Previous Topic:[CDO] delete object of removed class
Next Topic:Resolve eProxy with custom URI
Current Time: Sun Jul 27 22:21:12 EDT 2025
Powered by FUDForum. Page generated in 0.08064 seconds
