Home » Modeling » EMF » [Xcore]? Type of EAttributes always EJavaObject
[Xcore]? Type of EAttributes always EJavaObject [message #1737926] |
Thu, 14 July 2016 04:33  |
I'm currently trying to read an ecore model from an Xcore file. This is
my Xcore file:
package Sample
class C {
String s
Boolean b
int i
org.eclipse.emf.ecore.xml.^type.Boolean eb
And this is how I load the model (the code is run in Eclipse, that is,
it is invoked from an action, so the resource factory registries are set
up -- at least I assume that and most things work):
URI uri = URI.createFileURI(fileEditorInput.getPath().toString());
ResourceSet rs = new ResourceSetImpl();
res = rs.createResource(uri);
List<EObject> content = res.getContents();
Optional<EObject> optPackage =
content.stream().filter(e -> e instanceof EPackage).findFirst();
EPackage ePackage = (EPackage) optPackage.get();
Actually, the resource contains several models, that is:
[0] XPackage
[1] GenModel
[2] EPackage -- the one I select
[3] JvmGenericTypeImplCustom
... -- the "generated" Java classes
[10]JvmGenericTypeImplCustom
The EPackage "Sample" contains an EClass "C" as expected.
And the EClass "C" contains four EAttributes: "s", "b", i", and "eb" --
as expected.
But: The type of all attributes (EAttribute.eType, equals
EAttribute.eAttributeType) refers to a single EDataTypeImpl instance
with name "EJavaObject".
This really surprises me: I would have expected unresolved proxies or
something. But why do all attribute types refer to the very same
instance? Even the last one (which I only added for demonstrating
purposes, the type was suggested by content assist).
Do I need to pre-load other models? Do I have to configure the resource
set somehow? Do I have to pass some options when loading the resource?
Jens
Re: [Xcore]? Type of EAttributes always EJavaObject [message #1737941 is a reply to message #1737926] |
Thu, 14 July 2016 05:36   |
Jens,
So this is a project in the workspace? If you do Open With ->
Reflective Xcore Model Editor, does the Ecore model look okay there?
Perhaps it's just a problem that you should open it with a
platform:/resource URI because otherwise it won't know the IJavaProject
and won't be able to resolve references based on the scope.
On 14.07.2016 10:33, Jens v.P. wrote:
> is my Xcore file:
> package Sample
> class C {
> String s
> Boolean b
> int i
> set up -- at least I assume that and most things work):
> [0] XPackage
> [1] GenModel
> -- as expected.
> resource set somehow? Do I have to pass some options when loading the
> resource?
> Regards,
> Jens
Re: [Xcore]? Type of EAttributes always EJavaObject [message #1737949 is a reply to message #1737947] |
Thu, 14 July 2016 06:50   |
Jens,
Can you set a breakpoint in
org.eclipse.emf.ecore.xcore.util.XcoreEcoreBuilder.getEPackage(XPackage)?
It should call
org.eclipse.emf.ecore.xcore.ui.XcoreJavaProjectProvider.getJavaProject(ResourceSet).
That should create the class loader with the necessary classpath. Is
something going wrong here? Eventually
org.eclipse.emf.ecore.xcore.util.XcoreEcoreBuilder.link() and that
should link all the references, if they resolve.
I've also just noticed that you've only done a createResource, not a
getResource(uri, true). Somehow it was loaded anyway, but I wonder if
that's a problem too.
After you've loaded the resource (which it doesn't look like you're
doing explicitly), is the Ecore.genmodel in the resource set?
On 14.07.2016 12:22, Jens v.P. wrote:
> Dear Ed,
> Yes.
> Yes.
> I tried that, unfortunately without success:
> IFile file = fileEditorInput.getFile();
> String fp = file.getFullPath().toPortableString();
> URI platformURI = URI.createPlatformResourceURI(fp, true);
> res = rs.createResource(platformURI);
> The uri is correctly set to
> "platform:/resource/XCP/model/Sample.xcore" (my project is called XCP).
> The strange thing: I do not get any errors...
Re: [Xcore]? Type of EAttributes always EJavaObject [message #1737975 is a reply to message #1737949] |
Thu, 14 July 2016 11:33   |
Ed,
On 14.07.16 12:50, Ed Merks wrote:
> Jens,
> org.eclipse.emf.ecore.xcore.util.XcoreEcoreBuilder.getEPackage(XPackage)? It
> should call
All locations you mentioned are visited and no errors occur.
Again, this is how I load:
res = rs.getResource(platformURI, true);
res.load(Collections.emptyMap());
EcoreUtil.resolveAll(res);
In
XcoreEcoreBuilder.getEGenericType(XGenericType)
the type is supposed to be set. The type in the XAttribute is
xGenericType is an XGenericTypeImpl, it's type is a GenDataTypeImpl (and
it is a proxy, e.g.
eProxyURI:
platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel#//ecore/EBooleanObject)
This is never resolved correctly.
After the resolveAll call above, the resource set contains:
[0] XcoreResource with XPackage, GenModel (of Sample), EPackage (of
Sample) and some JvmGenericTypeImpls
[1] EcoreResourceFactoryImpl:
uri='platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel'
--> ah! and this contains a valudation error:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException:
org.eclipse.core.internal.resources.ResourceException: Resource
'/org.eclipse.emf.ecore/model/Ecore.genmodel' does not exist.
[2] EcoreResourceFactoryImpl:
uri:
uri='platform:/resource/org.eclipse.emf.ecore/model/XMLType.genmodel'
--> also with an error: Resource
'/org.eclipse.emf.ecore/model/XMLType.genmodel' does not exist.
Where do I have to set that URI? I thought that in the workspace, this
should be configured. I mean, the Xcore stuff is found and I have not
configured anything for that (my project even has no dependency to
Xcore...).
Current Time: Sun Jul 20 23:46:46 EDT 2025
Powered by FUDForum. Page generated in 0.04496 seconds
