Home » Modeling » Compare » CompareUI Dialog: 'Cancel' after merging raises an exception
CompareUI Dialog: 'Cancel' after merging raises an exception [message #1737566] Sun, 10 July 2016 04:02 Go to next message
I'm using CompareUI.openCompareDialog() to open a dialog programmatically with a comparison scope. I get an exception when I press the buttons to merge differences (left to right, etc.) and then press 'Cancel' to abort the whole process without affecting the compared models. Here's the trace:
!ENTRY org.eclipse.ui 4 0 2016-07-10 10:21:26.888
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
	at org.eclipse.swt.SWT.error(SWT.java:4491)
	at org.eclipse.swt.SWT.error(SWT.java:4406)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4155)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3772)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
	at org.eclipse.swt.SWT.error(SWT.java:4377)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
	at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:354)
	at org.eclipse.swt.widgets.Control.getParent(Control.java:1508)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.EMFCompareStructureMergeViewer.refreshTitle(EMFCompareStructureMergeViewer.java:618)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.EMFCompareStructureMergeViewer.access$14(EMFCompareStructureMergeViewer.java:615)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.EMFCompareStructureMergeViewer$25.run(EMFCompareStructureMergeViewer.java:1393)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	... 24 more
!ENTRY org.eclipse.ui 4 0 2016-07-10 10:21:26.891
!STACK 0
	... 24 more
Any ideas?
Best,
Matteo
[Updated on: Sun, 10 July 2016 04:29] by Moderator
Re: CompareUI Dialog: 'Cancel' after merging raises an exception [message #1737724 is a reply to message #1737566] Tue, 12 July 2016 05:07 Go to previous message
This bug has been fixed in 3.2.0.
Laurent Goubet
Obeo
Previous Topic:Opening CompareUI Dialog based on tutorial
Next Topic:UML Diagram for EMF Compare
Current Time: Sat Jul 26 02:57:15 EDT 2025
Powered by FUDForum. Page generated in 0.06355 seconds
