Home » Eclipse Projects » Equinox » Missing code signer information for third party JAR
Missing code signer information for third party JAR [message #1737647] Mon, 11 July 2016 10:41 Go to next message
Hello everybody,
I have a question regarding signed third party JARs in OSGI Bundles. It is about a custom ODA datasource for BIRT, but since I suspect my problem to be about the classloading, I used this forum - if I'm mistaken please shoot and I'll move the post.
My Goal:
Developing a BIRT ODA data source (as an OSGI bundle) which connects to a third party software. This software comes with a Java API, which is distributed in a signed JAR file. Furthermore this software enforces security checks to make sure that sensitive methods of the API are just called from their own (signed) classes. Hence they check the callers signature (see: docs.oracle.com/javase/7/docs/api/java/lang/Class.html#getSigners().
What I did so far:
I created an OSGI bundle via maven, which contained my custom classes as well as the third party JAR. To make sure the classloading works, I have added the JAR to my Bundles class path using the following line in my manifest (the whole manifest can be found attached):
Bundle-ClassPath: target/lib/fs-access-5.2.311.jar,.
The manifest of the third party JAR looks like this (I have stripped out the sensitive parts):
Manifest-Version: 1.0
Implementation-Title: ...
Implementation-Version: ...
Specification-Vendor: ...
Application-Name: ...
...-Revision: ...
Created-By: 1.7.0_80-b15 (Oracle Corporation)
...-BuildTime: 28.01.2016 12:13:18
...-Branch:
...-ReleaseTag: R3
Implementation-Vendor: ...
Ant-Version: Apache Ant 1.9.4
Trusted-Library: true
...-Version: 5.2.311
Permissions: all-permissions
Specification-Title: ...
Specification-Version: ...
Main-Class: de/.../.../client/SomeClass
Codebase: *
SHA1-Digest: nN9F/bXjncHe0sZsRJehnnvo5/4=
I'm using a fresh BIRT bundled eclipse to test my bundle, no additional configuration made. At least none that I'm aware of.
My Problem:
The bundle can be compiled, packaged and deployed to the BIRT eclipse instance without any problems. The classes of the third party JAR can be resolved and if I'm printing the classloader it says EquinoxClassLoader...
But as soon as I call sensitive API code (which invokes a security check) I'm getting an Exception like this:
Exception in thread "main" java.lang.SecurityException: Access denied to full.qualified.ClassName! Class full.qualified.ClassName has missing or invalid signature!
Also when I'm manually retrieving the signer information via docs.oracle.com/javase/7/docs/api/java/lang/Class.html#getSigners(), it won't work and I'm getting null.
I've worked with this API JAR for a very long time in standalone applications and web applications without any Issue, but I'm quite new to OSGI.
Can you please help me and suggest potential workarounds/means for a more detailed error analysis.
Thanks a lot in adance,
Martin
  • Attachment: MANIFEST.MF
    (Size: 0.56KB, Downloaded 201 times)
Re: Missing code signer information for third party JAR [message #1737677 is a reply to message #1737647] Mon, 11 July 2016 17:30 Go to previous messageGo to next message
Try setting the config.ini option:
osgi.signedcontent.support=certificate
By default equinox will not parse signatures at runtime.
See: http://help.eclipse.org/neon/topic/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html?resultof=%22%6f%73%67%69%2e%73%69%67%6e%65%64%63%6f%6e%74%65%6e%74%2e%73%75%70%70%6f%72%74%22%20#osgisignedcontentsupport
Re: Missing code signer information for third party JAR [message #1737705 is a reply to message #1737677] Tue, 12 July 2016 03:42 Go to previous message
Thanks for the quick reply!
Sadly setting this parameter didn't change anything.
Is there any known limitation with regards to nested signed JARs?
[Updated on: Tue, 12 July 2016 03:47] by Moderator
Previous Topic:BundleException: Error reading bundle content
Next Topic:Uninstall an eclipse plugin programmatically
Current Time: Sat Jul 26 11:38:26 EDT 2025
Powered by FUDForum. Page generated in 0.05121 seconds
