Home » Archived » BIRT » access report parameters from chart scripts
access report parameters from chart scripts [message #173457] Mon, 26 June 2006 12:14 Go to next message
Does someone know what is the easiest way to access the report parameters
within the chart script extension points (function beforeRendering(gcs,
context) in my case) ?
Thanks in advance, Thomas.
Re: access report parameters from chart scripts [message #173489 is a reply to message #173457] Mon, 26 June 2006 13:11 Go to previous messageGo to next message
context.getExternalContext().getScriptable().getParameterVal ue( "paramName")
should work.
David
"Thomas Escolan" <thomas_escolan@yahoo.fr> wrote in message
news:3ffd171be790f611fd001d476e1c1810$1@www.eclipse.org...
> Hello,
Re: access report parameters from chart scripts [message #173694 is a reply to message #173489] Tue, 27 June 2006 06:10 Go to previous messageGo to next message
OK, thanks, so I did this in my chart scripts :
formatter = new java.text.SimpleDateFormat("HH:mm",
java.util.Locale.FRANCE);
function beforeRendering(gcs, context) {
var date =
context.getExternalContext().getScriptable().getParameterVal ue( "date");
if (date == null) {
date = new java.util.Date();
var chart = context.getChartInstance();
var title = chart.getTitle().getLabel().getCaption();
title.setValue(title.getValue() + " " + formatter.format((java.util.Date)
date));
BUT it fails on casting syntax (not supported, I guess) : is there a
clever way to do a call to ambiguously delcared methods ??
Re: access report parameters from chart scripts [message #173741 is a reply to message #173694] Tue, 27 June 2006 07:24 Go to previous messageGo to next message
Please check the Rhino syntax to see how to do this:
http://www.mozilla.org/rhino/
David
news:1e24beca87adaaa6df759a05df2a3602$1@www.eclipse.org...
> var date =
> if (date == null) {
> date));
Re: access report parameters from chart scripts [message #173747 is a reply to message #173741] Tue, 27 June 2006 07:43 Go to previous messageGo to next message
Great ! Thank you, David.
Re: access report parameters from chart scripts [message #173761 is a reply to message #173747] Tue, 27 June 2006 08:47 Go to previous message
For curious ones :
var date =
if (date == null) {
formatter["format(java.util.Date)"](date));
Previous Topic:Transparent background in a graphic : bug ?
Next Topic:Dynamic Date formatting
Current Time: Tue Sep 16 00:42:49 EDT 2025
Powered by FUDForum. Page generated in 0.04751 seconds
