Home » Newcomers » Newcomers » Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equinox.launche
Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equinox.launche [message #1737480] Fri, 08 July 2016 10:57 Go to next message
I decided to open up Eclipse today and for some reason I got that error. Eclipse has worked until today, and "Programs and Features" does not show that any new programs have been installed. I have tried restarting and reinstalling Eclipse, the JRE, and the JDK, and nothing has worked. If there are any logs or other information that I should supply, please tell me.
The full path shown in the error message is:
C:\Users\oreo4\eclipse\java-neon\eclipse\plugins/org.eclipse.equinox.launcher_1.3.200.v20160318-1642.jar
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equinox [message #1737496 is a reply to message #1737480] Fri, 08 July 2016 12:44 Go to previous messageGo to next message
Riley,
Did you try installing to a new fresh location? Does that installation
have a plugins folder with that file in it?
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equinox [message #1737517 is a reply to message #1737496] Fri, 08 July 2016 17:50 Go to previous messageGo to next message
I have not tried installing to a different location, but the current installation location does have a plugins folder with that .jar file.
EDIT: Actually, the file is not the same name, it is version 201 instead of the version 200 that eclipse wants. What can I do to fix this?
[Updated on: Fri, 08 July 2016 17:52] by Moderator
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equ [message #1737527 is a reply to message #1737517] Sat, 09 July 2016 02:26 Go to previous messageGo to next message
Riley,
Did you install using the installer or by unzipping one of the packaged
zips?
If you used the installer, try installing to a new location (or
delete/rename/move the old installation first before installing there
again).
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equ [message #1737538 is a reply to message #1737527] Sat, 09 July 2016 11:03 Go to previous messageGo to next message
Ed Merks wrote on Sat, 09 July 2016 06:26
Riley,
zips?
again).
I did try deleting the previous installation before reinstalling, but I'll try installing it to a new directory.
Turns out, I needed to delete the .eclipse folder in my Users\oreo4 directory before reinstalling. It seems to be working now!
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equ [message #1737586 is a reply to message #1737538] Sun, 10 July 2016 18:49 Go to previous messageGo to next message
Turns out, after another day, it's giving me the same exact error.
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse [message #1737593 is a reply to message #1737586] Mon, 11 July 2016 02:11 Go to previous messageGo to next message
Did you install something extra during that day? What does your
eclipse.ini look like? You said the file at that path exists. Is it
non-empty? It's a jar, so can you unzip it to look at the contents?
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse [message #1737646 is a reply to message #1737593] Mon, 11 July 2016 10:40 Go to previous messageGo to next message
I installed a few games, and AMD installed their Dual-Core Optimizer, but nothing Java related. The path does not exist, a similarly named file one version newer exists in that folder.
My eclipse.ini looks like this:
-startup
--launcher.library
C:\Users\oreo4\.p2\pool\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.400.v20160518-1444
-product
org.eclipse.epp.package.java.product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.appendVmargs
-vmargs
-Dosgi.requiredJavaVersion=1.8
-XX:+UseG1GC
-XX:+UseStringDeduplication
-Xms256m
-Xmx1024m
-Declipse.p2.max.threads=10
-Doomph.update.url=http://download.eclipse.org/oomph/updates/milestone/latest
-Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/
Ed Merks wrote on Mon, 11 July 2016 06:11
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.ecl [message #1737657 is a reply to message #1737646] Mon, 11 July 2016 11:39 Go to previous messageGo to next message
Riley,
Comments below.
It was more a question, did you install things into your Eclipse IDE.
What exactly is the name of the file in the plugins folder of the
installation? In my Neon installations it's exactly
org.eclipse.equinox.launcher_1.3.200.v20160318-1642 as you show below.
And this is the newest released version of this plugin...
In any case, the name of the launcher jar actually in the installation's
plugins folder must match exactly the -start argument.
When it worked they must have been the same. It should (could) only
change as a result of installing something in the IDE.
> -startup
> --launcher.library
> -product
> openFile
> -showsplash
> -vmargs
> -XX:+UseG1GC
> -Xms256m
> -Xmx1024m
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.ecl [message #1737663 is a reply to message #1737657] Mon, 11 July 2016 12:42 Go to previous messageGo to next message
I don't understand what you mean by "Comments below".
EDIT: Never mind, realized you wrote in the middle of my post. The name of the file in the plugins folder was org.eclipse.equinox.launcher_1.3.201.v20160318-1642.jar, but now it is the normal one. Still getting the error.
Ed Merks wrote on Mon, 11 July 2016 15:39
Riley,
Comments below.
> -startup
> --launcher.library
> -product
> openFile
> -showsplash
> -vmargs
> -XX:+UseG1GC
> -Xms256m
> -Xmx1024m
[Updated on: Mon, 11 July 2016 12:52] by Moderator
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org [message #1737665 is a reply to message #1737663] Mon, 11 July 2016 12:48 Go to previous messageGo to next message
That mean my comments inline mixed between your comments.
To repeat them...
>> Riley,
>> Comments below.
>> Optimizer, > but nothing Java related. It was more a question, did
>> > The path does not exist, a similarly named file one version newer >
>> below. And this is the newest released version of this plugin...
>> installation's plugins folder must match exactly the -start argument.
>> > -startup
>> > --launcher.library
>> > -product
>> > openFile
>> > -showsplash
>> > -vmargs
>> > -XX:+UseG1GC
>> > -Xms256m
>> > -Xmx1024m
>> it >> non-empty? It's a jar, so can you unzip it to look at the
>> contents?
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org [message #1737666 is a reply to message #1737665] Mon, 11 July 2016 12:54 Go to previous messageGo to next message
Figured it out a bit after posting that, I edited my original post. Before I fixed it the first time, it was named org.eclipse.equinox.launcher_1.3.201.v20160318-1642.jar, but now it is the current and correct name. I have unzipped it and it is non-empty, and contains the main class, and plenty of other things that look like the proper file structure.
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org [message #1737858 is a reply to message #1737665] Wed, 13 July 2016 10:31 Go to previous messageGo to next message
I've tried installing it again and figured out that it only works on the first run after installation.
Ed Merks wrote on Mon, 11 July 2016 16:48
To repeat them...
>> Riley,
>> Comments below.
>> > -startup
>> > --launcher.library
>> > -product
>> > openFile
>> > -showsplash
>> > -vmargs
>> > -XX:+UseG1GC
>> > -Xms256m
>> > -Xmx1024m
>> contents?
Re: Eclipse Error on start - "Failed to find main class in C:\Users\... [message #1737866 is a reply to message #1737858] Wed, 13 July 2016 11:18 Go to previous messageGo to next message
Riley,
So it works only when it's launched by the installer that first time?
I.e., did you launch it from the installer? Have you tried installing
one (to a new location), not launching it from the installer, but
launching it manually? Does that already fail without ever having
launched it before? How are you launching it manually? Double clicking
the *.exe in a Window's Explorer? If you launch it (when that works),
and do a File -> Restart, does that work? But if you really exit and
launch again (without having installed anything or done much of anything
in the IDE), then it won't start again?
Re: Eclipse Error on start - "Failed to find main class in C:\Users\... [message #1759752 is a reply to message #1737866] Tue, 18 April 2017 04:09 Go to previous messageGo to next message
Riley,
did you manage to fix this issue? I have the same problem....
Marian
Re: Eclipse Error on start - "Failed to find main class in C:\Users\... [message #1759838 is a reply to message #1759752] Tue, 18 April 2017 17:24 Go to previous message
Last time someone had this problem, I too asked a bunch of questions, but I got no answers, so I don't expect you'll get answers either.
In the end, we need details to understand what's going wrong. If no one provides details, we can't really help...
Previous Topic:Where does Eclipse store its settings? (Mac OS)
Next Topic:Lack of classic text editor macros
Current Time: Sun Jul 27 14:34:39 EDT 2025
Powered by FUDForum. Page generated in 0.12136 seconds
