[CDO] NPE in AbstractHorizintalClassMapping.initTable() [message #1737467] |
Fri, 08 July 2016 09:02  |
I am using CDO 4.4.1.v20160215 in Kepler
Here is my stack trace, which occurs when I try to save the model
!STACK 0
org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore: java.lang.NullPointerException
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.initTable(AbstractHorizontalClassMapping.java:127)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.<init>(AbstractHorizontalClassMapping.java:111)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditClassMapping.<init>(HorizontalAuditClassMapping.java:94)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditMappingStrategy.doCreateClassMapping(HorizontalAuditMappingStrategy.java:48)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.createClassMapping(AbstractMappingStrategy.java:678)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getClassMapping(AbstractMappingStrategy.java:726)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.queryXRefs(AbstractHorizontalMappingStrategy.java:164)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.queryXRefs(HorizontalMappingStrategy.java:189)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.queryXRefs(DBStoreAccessor.java:337)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext$XRefContext.getXRefs(TransactionCommitContext.java:1601)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.checkXRefs(TransactionCommitContext.java:1267)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:647)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:48)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:1144)
at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:1137)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:293)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:101)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:110)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:98)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:100)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:369)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:73)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:67)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:89)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1316)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1290)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1257)
at com.yambina.edm.commons.platform.internalservices.EResourceService.commit(EResourceService.java:339)
at com.yambina.edm.commons.platform.EDMPlatform$3.run(EDMPlatform.java:293)
I used the CDO Explorer view to open the model and when I try to save it I get the same exception.
The tablename it is trying to init is the EAnnotation table (line 118 of AbstractHorizontalClassMapping) There is no schemaTransaction set for IDBDatabase.
Some guidance on how to debug this would be welcome.
FUDForum. Page generated in 0.24347 seconds
