Home » Modeling » EMF » [CDO] NPE in AbstractHorizintalClassMapping.initTable()(Is this a bug? )
[CDO] NPE in AbstractHorizintalClassMapping.initTable() [message #1737467] Fri, 08 July 2016 09:02 Go to next message
I am using CDO 4.4.1.v20160215 in Kepler
Here is my stack trace, which occurs when I try to save the model
!STACK 0
org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore: java.lang.NullPointerException
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.initTable(AbstractHorizontalClassMapping.java:127)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.<init>(AbstractHorizontalClassMapping.java:111)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditClassMapping.<init>(HorizontalAuditClassMapping.java:94)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditMappingStrategy.doCreateClassMapping(HorizontalAuditMappingStrategy.java:48)
	at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.createClassMapping(AbstractMappingStrategy.java:678)
	at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getClassMapping(AbstractMappingStrategy.java:726)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.queryXRefs(AbstractHorizontalMappingStrategy.java:164)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.queryXRefs(HorizontalMappingStrategy.java:189)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.queryXRefs(DBStoreAccessor.java:337)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext$XRefContext.getXRefs(TransactionCommitContext.java:1601)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.checkXRefs(TransactionCommitContext.java:1267)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:647)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:48)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
	at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:1144)
	at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:1137)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:293)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:101)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:110)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:98)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:100)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:369)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:73)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:67)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:745)
	at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:89)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1316)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1290)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1257)
	at com.yambina.edm.commons.platform.internalservices.EResourceService.commit(EResourceService.java:339)
	at com.yambina.edm.commons.platform.EDMPlatform$3.run(EDMPlatform.java:293)
I used the CDO Explorer view to open the model and when I try to save it I get the same exception.
The tablename it is trying to init is the EAnnotation table (line 118 of AbstractHorizontalClassMapping) There is no schemaTransaction set for IDBDatabase.
Some guidance on how to debug this would be welcome.
Re: [CDO] NPE in AbstractHorizintalClassMapping.initTable() [message #1737470 is a reply to message #1737467] Fri, 08 July 2016 09:37 Go to previous messageGo to next message
Am 08.07.2016 um 16:02 schrieb David Wynter:
Kepler is very old, but probably unrelated to CDO issues.
CDO 4.4 is also out of maintenance. Have you tried the same scenario with the just release CDO 4.5?
What database are you using?
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
You could try the same usage scenario without referential integrity checks. That could gives us some pointers.
> at
> at
> at
> at
I'd need exact steps to follow in order to reproduce the problem ;-(
It would probably be good to set a breakpoint on the line that acquires the null pointer and then step through the code.
Depending on what you find out I might be able to give more advice.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] NPE in AbstractHorizintalClassMapping.initTable() [message #1737484 is a reply to message #1737470] Fri, 08 July 2016 11:06 Go to previous messageGo to next message
I'll upgrade to 4.5. As you said in earlier advice to me CDO is independent of the Eclipse version, at least as far back a Kepler, which we have to use for a while yet.
Re: [CDO] NPE in AbstractHorizintalClassMapping.initTable() [message #1737565 is a reply to message #1737484] Sun, 10 July 2016 01:47 Go to previous message
Am 08.07.2016 um 18:06 schrieb David Wynter:
Great. You'll let us know how it goes ;-)
That is correct. At least for the non-UI parts of Net4j and CDO.
Cheers
/Eike
Previous Topic:[CDO] CDOViews and controlling updates
Next Topic:CDO mapping with UUIDs
Current Time: Sun Jul 27 06:42:49 EDT 2025
Powered by FUDForum. Page generated in 0.44793 seconds
