GMF Eclipse 4 Batik dependency Problem [message #1737212] |
Wed, 06 July 2016 08:53  |
I'm currently trying to use GMF in an Eclipse RCP application. I'm using Eclipse Neon. The RCP application uses the 3.x comp layer.
When I add the generated Editor plug-in to my run configuration and add the required plug-in using the button in the run configuration editor, the application starts but the graphical editor plug-in cannot be loaded due to missing dependencies to batik 1.6 plug-ins.
When I add the batik 1.6 plug-ins to the run configuration, my application does not start any more, because the plug-in that defines the application cannot be loaded, because it does not find the batik 1.7 plug-in any more.
So, if I only using batik 1.6, the application does not start. If I'am only using 1.7 the application starts, but the graphical editor is not loaded. If I'am using both versions, the application does not start because 1.6 is loaded prior to 1.7 and the plug-in that defines the application cannot be loaded.
However, when I create a run configuration that includes all plug-ins of my Eclipse installation, the graphical editor plug-in is loaded correctly.
I already searched the web, but didn't find any solution. Any idea, how this problem can be fixed?
Stephan
Re: GMF Eclipse 4 Batik dependency Problem [message #1737452 is a reply to message #1737212] |
Fri, 08 July 2016 07:43  |
Okay, after I aded org.eclipse.equinox.simpleconfigurator it works and the dependency problem seems to be solved.
Now my question: Is this a missing dependency of GMF runtime or a bug in another project?
[Updated on: Fri, 08 July 2016 07:44] by Moderator
FUDForum. Page generated in 0.05170 seconds
