Cyclic linking detected when building in maven [message #1736601] |
Thu, 30 June 2016 10:20  |
I am stuck. My DSL provides a scoping which works nice in Eclipse, but when I try to build the project with maven it fails with:
DefaultComponentFeatureDotRef.right->DefaultComponentFeatureDotRef.right
What is the difference between the maven build and the Eclipse build?
Why does it fails with maven?
Any help, hint welcome.
Re: Cyclic linking detected when building in maven [message #1736926 is a reply to message #1736909] |
Mon, 04 July 2016 08:02   |
acceptor.accept(comp.toClass(className))[
val start = System.currentTimeMillis
lateInitializationSetupComponent(it, comp.name, comp.toJvmType, comp.content)
static = false
printDuration("create Component "+comp.name+": ", start)
to
acceptor.accept(comp.toClass(className, [
static = false
But this raises other issues, but I hope I can cope with them.
Re: Cyclic linking detected when building in maven [message #1737441 is a reply to message #1736963] |
Fri, 08 July 2016 05:46   |
Thank you for the replay, I found an other solution. It looks different, but my real dsl is much more complex.
I had to override org.eclipse.xtext.xbase.resource.BatchLinkableResource as in my case the cycle seems to be the normal behavior.
I am doing something like this
File one contains:
defaultObject = new XYZObject (xyzAttribute1 = "x", xyzAttribute2="x2", ...)
File two contains:
aNewObject = extends defaultObject (xyzA1 = "x", xyzAttribute2="x2", ...)
To create the sope for xyzA1 I need to find the JvmType of XYZObject. When I try to resolve the type of XYZObject the whole model of "File one" seems to be parsed, and this causes the cycle. At the second call the model of "File one" has been parsed, so the cycle is broken.(At least this is my guess)
val counter = new HashMap<Triple<EObject, EReference, INode>, AtomicInteger>()
override protected handleCyclicResolution(Triple<EObject, EReference, INode> triple) throws AssertionError {
try{
val calls = incrementAndGetCounter(triple)
if (calls > 3)
super.handleCyclicResolution(triple)
} else
val node = triple.third
val message = "Cyclic linking detected " +calls+": "+ getReferences(triple, resolving)+"\n"
+" "+getReferencesNode(triple, resolving)
println(message)
// new Exception(message).printStackTrace
val linkedObjects = getLinkingService().getLinkedObjects(
triple.first,
triple.second,
node);
linkedObjects.head
} finally
decrepementAndGetCounter(triple)
def int incrementAndGetCounter (Triple<EObject, EReference, INode> triple)
val c = counter.get(triple)
if (c == null)
counter.put(triple, new AtomicInteger(1))
1
} else
c.incrementAndGet
def int decrepementAndGetCounter (Triple<EObject, EReference, INode> triple)
if (c == null)
counter.put(triple, new AtomicInteger(-1))
(-1)
} else
c.decrementAndGet
def protected String getReferencesNode(Triple<EObject, EReference, INode> triple,
LinkedHashSet<Triple<EObject, EReference, INode>> resolving2) {
val buffer = new StringBuffer();
var found = false;
for (Triple<EObject, EReference, INode> triple2 : resolving2) {
found = found || triple2.equals(triple);
if (found)
buffer.append(getQualifiedNodeName(triple2.third)).append("->");
buffer.append(getQualifiedNodeName(triple.third));
return buffer.toString();
def private String getQualifiedNodeName(INode node) {
return node.text;
In my case the cycle only occurred once.
Cyclic linking detected 1: EmuContentRef.emuContent->Parameter.parameterFeature->EmuContentRef.emuContent
chuteTp->unitId->chuteTp
Cyclic linking detected 1: JvmParameterizedTypeReference.type->Parameter.parameterFeature->JvmParameterizedTypeReference.type
VarioscNodeComponent->nodeIdVariosc-> VarioscNodeComponent
defaultTp->name->defaultTp
I am fine with this solution. And for now it works.
But it does not answers the question, why it is behaving different in Eclipse, than in Maven. (But for now I am happy )
FUDForum. Page generated in 0.07667 seconds
