Home » Eclipse Projects » Virgo » Virgo 3.6.4 + Apache CXF 3.1.4 = ClassNotFound(When deploying a service a ClassNotFoundException is thrown)
Virgo 3.6.4 + Apache CXF 3.1.4 = ClassNotFound [message #1737321] |
Thu, 07 July 2016 05:48  |
I'm trying to deploy a service in Virgo using CXF.
When I try this, I get a ClassNotFoundException for "org.springframework.util.ClassUtils" from the user region BundleLoader.
The class is in the jar that comes with the release: repository/ext/org.springframework.core_3.1.0.RELEASE.jar
And the package is defined as an optional dependency in "org.apache.cxf.cxf-core":
org.springframework.util;version="[3.1,5)";resolution:=optional
Where can I look now?
Re: Virgo 3.6.4 + Apache CXF 3.1.4 = ClassNotFound [message #1737324 is a reply to message #1737321] |
Thu, 07 July 2016 06:08   |
Hi Bill,
a colleague of mine successfully used CXF in Virgo by packaging it as nested Jars within the bundle containing the WebServices code.
He went for this approach because he had to support both Virgo and another commercial Application Server that does not include the Spring Jars out of the box and he wanted to have a portable solution that would work in both containers .
I am attaching here an extract from his bundle MANIFEST.MF file. I removed some imports that I believe were unrelated to CXF but the sample below may still include unnecessary dependencies (or I may have deleted too many). In any case, while this is not what you are trying to do, I hope it may help you in finding out whether you have all of the required dependencies in place.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-SymbolicName: whatever
Bundle-Version: 1.0.0.qualifier
Bundle-Vendor: acme
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Import-Package:
javax.activation,
javax.annotation,
javax.annotation.security;version="1.1.0",
javax.crypto,
javax.jws,
javax.jws.soap,
javax.management,
javax.naming,
javax.persistence;version="2.1",
javax.persistence.criteria;version="2.1.0",
javax.persistence.metamodel;version="2.1.0",
javax.persistence.spi;version="2.1.0",
javax.security.auth,
javax.security.auth.callback,
javax.security.auth.login,
javax.servlet,
javax.servlet.http,
javax.ws.rs;version="1.1.0",
javax.ws.rs.core;version="1.1.0",
javax.ws.rs.ext;version="1.1.0",
javax.wsdl;version="1.6.0",
javax.wsdl.extensions;version="1.6.0",
javax.wsdl.extensions.http;version="1.6.0",
javax.wsdl.extensions.mime;version="1.6.0",
javax.wsdl.extensions.schema;version="1.6.0",
javax.wsdl.extensions.soap;version="1.6.0",
javax.wsdl.extensions.soap12;version="1.6.0",
javax.wsdl.factory;version="1.6.0",
javax.wsdl.xml;version="1.6.0",
javax.xml,
javax.xml.bind;version="2.0.0",
javax.xml.bind.annotation;version="2.0.0",
javax.xml.bind.annotation.adapters;version="2.0.0",
javax.xml.bind.attachment;version="2.0.0",
javax.xml.bind.helpers;version="2.0.0",
javax.xml.bind.util;version="2.0.0",
javax.xml.datatype,
javax.xml.namespace,
javax.xml.parsers,
javax.xml.soap,
javax.xml.stream,
javax.xml.stream.events,
javax.xml.stream.util,
javax.xml.transform,
javax.xml.transform.dom,
javax.xml.transform.sax,
javax.xml.transform.stax,
javax.xml.transform.stream,
javax.xml.validation,
javax.xml.ws,
javax.xml.ws.handler,
javax.xml.ws.handler.soap,
javax.xml.ws.http,
javax.xml.ws.soap,
javax.xml.ws.spi,
javax.xml.ws.spi.http;resolution:=optional,
javax.xml.ws.wsaddressing,
javax.xml.xpath,
junit.framework;version="3.8.1";resolution:=optional,
org.w3c.dom,
org.w3c.dom.ls,
org.xml.sax
Bundle-ClassPath: .,
lib/spring-core-3.2.6.RELEASE.jar,
lib/spring-aop-3.2.6.RELEASE.jar,
lib/spring-beans-3.2.6.RELEASE.jar,
lib/spring-context-3.2.6.RELEASE.jar,
lib/spring-expression-3.2.6.RELEASE.jar,
lib/spring-web-3.2.6.RELEASE.jar,
lib/cxf-core-3.0.3.jar,
lib/cxf-rt-transports-http-3.0.3.jar,
lib/neethi-3.0.3.jar,
lib/xmlschema-core-2.1.0.jar,
lib/cxf-rt-frontend-jaxws-3.0.3.jar,
lib/cxf-rt-wsdl-3.0.3.jar,
lib/cxf-rt-bindings-soap-3.0.3.jar,
lib/wss4j-bindings-2.0.2.jar,
lib/wss4j-policy-2.0.2.jar,
lib/wss4j-ws-security-common-2.0.2.jar,
lib/wss4j-ws-security-dom-2.0.2.jar,
lib/wss4j-ws-security-policy-stax-2.0.2.jar,
lib/wss4j-ws-security-stax-2.0.2.jar,
lib/woodstox-core-asl-4.4.1.jar,
lib/stax2-api-3.1.4.jar,
lib/cxf-rt-databinding-jaxb-3.0.3.jar,
lib/cxf-rt-frontend-simple-3.0.3.jar,
lib/geronimo-addressing.jar,
lib/xmlsec-2.0.2.jar,
lib/cxf-rt-ws-security-3.0.3.jar,
lib/jasypt-1.9.2.jar,
lib/commons-codec-1.10.jar
Current Time: Sun Jul 20 20:21:21 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
