Home » Modeling » Papyrus » Papyrus 2.0 doesn't start under ubuntu 15.1(Error when I try to lunch papyrus 2.0.0 Neon)
Papyrus 2.0 doesn't start under ubuntu 15.1 [message #1737167] Wed, 06 July 2016 04:19 Go to next message
When I lunch the downloaded pack I get an error message with the attached log.
I'm using a 64bit machine with ubuntu 15.1, where eclipse is just used (Luna version) for embedded software development.
Does someone know which is the problem?
Thanks.
Andrea
Re: Papyrus 2.0 doesn't start under ubuntu 15.1 [message #1737298 is a reply to message #1737167] Thu, 07 July 2016 01:25 Go to previous messageGo to next message
Papyrus 2.0 is based in Eclipse Neon, which requires Java 1.8. However, the log you have attached shows that the java that have been found and used to launch Papyrus is Java 1.7 (see the java version line).
Do you have a correct Java runtime environment installed?
Re: Papyrus 2.0 doesn't start under ubuntu 15.1 [message #1737301 is a reply to message #1737167] Thu, 07 July 2016 03:16 Go to previous message
Your log is showing number version between 1.2.0 and 2.0.0 so you are Problably trying to install papyrus Neon on Eclipse Luna
Either use Eclipse neon as base
Or us Luna update site http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/luna
Benoit
Previous Topic:ClassNotFound when adding a Matcher to an ElementTypesConfiguration
Next Topic:Performing UML package merge
Current Time: Fri Oct 31 18:26:08 EDT 2025
Powered by FUDForum. Page generated in 0.05150 seconds
