Home » Eclipse Projects » Sirius » Export custom figures
Export custom figures [message #1737100] Tue, 05 July 2016 12:53 Go to next message
I am using Sirius 4.0.
I have defined several custom edit parts, and corresponding Draw2D/GEF figures. When I attempt to export to anything other than JPEG, I get an error (for SVG, for example):
The class org.eclipse.sirius.diagram.ui.tools.internal.render.SiriusGraphicsSVG has not implemented this new graphics function.
In fact, JPEG doesn't even work correctly as my two labels (defined using the Draw2D label and FlowPage figures) are not being displayed.
My question is whether this should be expected or if it is a bug? If expected, is there a mechanism by which I can define export functions for my figures?
Re: Export custom figures [message #1737139 is a reply to message #1737100] Wed, 06 July 2016 02:03 Go to previous messageGo to next message
Hi Iain,
Le 05/07/2016 à 18:53, Iain Whiteside a écrit :
> The class
Do you have the complete error stack ? It might help us to identify the
problem.
> for my figures?
I looked in SiriusGraphicsSVG hierarchy and found the following
candidates methods which will throws the same exception:
.. translate(float, float) -> try to use translate(int, int)
.. shear(float, float)
.. setTextAntialias(int)
.. setLineDashOffset(float)
.. setInterpolation(int)
.. setForeGroundPattern(Pattern)
.. scale(foat, float) -> try to use scale(double)
.. rotate(float)
.. getTextAntialias()
.. getLineMiterLimit()
.. getLineCap()
.. getLineJoin()
Note that SiriusGraphicsSVG/SiriusGraphicsToGraphics2DAdaptor have been
copied from
org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.graphics.GraphicsToGraphics2DAdaptor/org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.export.GraphicsSVG
which seems to correct some of those issues.
We might need more clues (the stack will be a good start) to be able to
help you to find which method causes the rpoblem in your case and give
some advices to wrokaround the problem in a first time.
Could you open a Bugzilla [1] to track the issue ?
Maxime - Obeo
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Re: Export custom figures [message #1737141 is a reply to message #1737139] Wed, 06 July 2016 02:19 Go to previous messageGo to next message
> copied from
I wrongly read getTextAntialias instead of getAntialias(). After a
closer look as the classes we used to copy, they did not change since
our copy, so the problem you encounter would also occur during export of
image ith the default GMF classes.
Maxime - Obeo
Re: Export custom figures [message #1737285 is a reply to message #1737141] Wed, 06 July 2016 18:44 Go to previous messageGo to next message
Thanks for the helpful replies.
It looks like the problem stems from my use of org.eclipse.draw2d.Graphics.setBackgroundPattern(Pattern p), which is not supported in the Graphics class that SiriusGraphicsSVG extends. In fact, SiriusGraphicsToGraphics2DAdaptor provides a method using GradientPoint, which is the java.awt equivalent. Is this a mistake, or is there a missing translation from Pattern to GradientPoint? I can file a bugzilla if required.
Re: Export custom figures [message #1738546 is a reply to message #1737285] Wed, 20 July 2016 13:50 Go to previous messageGo to next message
Just checking if the behaviour mentioned in my previous reply is intended or a bug? Shall I open a bugzilla?
Thanks!
Iain
Re: Export custom figures [message #1738587 is a reply to message #1738546] Thu, 21 July 2016 03:12 Go to previous message
Le 20/07/2016 à 19:50, Iain Whiteside a écrit :
The behavior you mention is intended : the image generator creates AWT
images.
For your background pattern case, you might look at
org.eclipse.sirius.diagram.ui.tools.api.figure.GradientHelper.setColorsGradation(Graphics,
ViewGradientFigureDesc) which is used by Sirius to handle the gradient
of containers (in
org.eclipse.sirius.diagram.ui.tools.api.figure.GradientRoundedRectangle.fillShape(Graphics)
for example). It will do is the translation from Pattern to
GradientPoint for you, if you have the good type of figure. Otherwise
you will see how we manage and cache it.
> Thanks!
> Iain
Maxime - Obeo
Previous Topic:Update cells in a cross table
Next Topic:Prevent Default Sirius ViewOrdering
Current Time: Mon Nov 03 14:24:13 EST 2025
Powered by FUDForum. Page generated in 0.05004 seconds
