Home » Modeling » TMF (Xtext) » xtext with multiple file extensions(xtext with multiple file extensions)
xtext with multiple file extensions [message #1736893] Mon, 04 July 2016 05:18 Go to next message
Can I have multiple file extensions for xtext editor?
I can have extensions like test.jpl, test.scr, test.jam. All have the same type of parser rules.
Re: xtext with multiple file extensions [message #1736895 is a reply to message #1736893] Mon, 04 July 2016 05:25 Go to previous messageGo to next message
Is it possible to configure it in the .mwe2 file as a comma-separated list.
Re: xtext with multiple file extensions [message #1736898 is a reply to message #1736895] Mon, 04 July 2016 05:28 Go to previous messageGo to next message
yes. dont forget to merge (maybe copy) plugin.xml_gen changed contents to plugin.xml
Re: xtext with multiple file extensions [message #1736899 is a reply to message #1736898] Mon, 04 July 2016 05:33 Go to previous messageGo to next message
After adding the comma separated extension in .mwe2 file I generated artifacts. Nothing has changed in plugin.xml_gen. Contents in plugin.xml and plugin.xml_gen are same.
Re: xtext with multiple file extensions [message #1736900 is a reply to message #1736899] Mon, 04 July 2016 05:35 Go to previous messageGo to next message
can you share e.g. the
<extension point="org.eclipse.xtext.builder.participant">
<participant
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.builder.IXtextBuilderParticipant"
fileExtensions="mydsl"/>
</extension>
of the plugin.xml in mydsl.ui
Re: xtext with multiple file extensions [message #1736912 is a reply to message #1736900] Mon, 04 July 2016 07:20 Go to previous messageGo to next message
<participant
class="com.prolifics.jpl.ui.JPLEditorExecutableExtensionFactory:org.eclipse.xtext.builder.IXtextBuilderParticipant"
fileExtensions="jpl,scr,jam,asc"/>
</extension>
Re: xtext with multiple file extensions [message #1736913 is a reply to message #1736912] Mon, 04 July 2016 07:24 Go to previous messageGo to next message
then it should work fine
Re: xtext with multiple file extensions [message #1736914 is a reply to message #1736912] Mon, 04 July 2016 07:24 Go to previous message
Its working sir. Sorry. It just copied the extension first now I replaced entire plugin.xml with plugin_XML_gen
[Updated on: Mon, 04 July 2016 07:26] by Moderator
Previous Topic:Xtext Dependencies for RCP Applications
Next Topic:[SOLVED] Strange erroneous behavior of xtext-maven-plugin
Current Time: Mon Jul 21 02:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.06936 seconds
