Home » Eclipse Projects » Eclipse 4 » Unable to launch RCP with @nodefault after upgrading to neon
Unable to launch RCP with @nodefault after upgrading to neon [message #1736863] Sun, 03 July 2016 23:13 Go to next message
we have a 3.x based rcp running compatibility fine in 4.5.1 since that came out. I upgraded to neon to try it out and am unable to launch. we launch with @nodefault for instance location as we allow our user to pick from various servers and then set the instancelocation programatically based on their selection so they can run multiple instances of the app at the same time. If I set the location to something arbitrary we launch fine, but then of course we can't set the workspace programatically because of the inability to 'change' the workspace once it is set.
The ResourcePlugin appears to now need the instancelocation set before it used to (just guessing):
ResourcesPlugin.start throws an exception
Caused by: java.lang.IllegalStateException: The instance data location has not been specified yet.
Looking for ways to get @nodefault working again if anyone has any idea.
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 43 more
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:54)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:124)
at org.eclipse.core.internal.runtime.InternalPlatform.getStateLocation(InternalPlatform.java:539)
at org.eclipse.core.runtime.Plugin.getStateLocation(Plugin.java:289)
at org.eclipse.core.internal.resources.LocalMetaArea.<init>(LocalMetaArea.java:59)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:456)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
Re: Unable to launch RCP with @nodefault after upgrading to neon [message #1797504 is a reply to message #1736863] Wed, 31 October 2018 15:18 Go to previous messageGo to next message
Did you find a solution to your problem?
I am stuck with the same exact issue.
Re: Unable to launch RCP with @nodefault after upgrading to neon [message #1797505 is a reply to message #1797504] Wed, 31 October 2018 15:22 Go to previous message
Sadly, no. So we were never able to upgrade our RCP to use 4.6
Previous Topic:default dark theme - @import url seems to not import color definitions or they are overriden
Next Topic:Opening new Part - getting current EPartService from static method
Current Time: Sun Nov 09 08:34:51 EST 2025
Powered by FUDForum. Page generated in 0.23839 seconds
