Home » Eclipse Projects » Oomph » What could cause additional repository & requirement to be ignored in an existing working model?
What could cause additional repository & requirement to be ignored in an existing working model? [message #1736354] Tue, 28 June 2016 14:19 Go to next message
any idea what may be causing an additional repository & requirement to be ignored in an existing working model?
I have like 20+ repos & features in https://github.com/vorburger/opendaylight-eclipse-setup/blob/master/org.opendaylight.projects.setup, so I think I know what I'm doing (hopefully), but I'm struggling why I can't get https://github.com/vorburger/opendaylight-eclipse-setup/compare/localTerminal to work - it just does ... nothing! In the Log from Perform Setup Tasks, it says "Loading platform:/resource/org.opendaylight.eclipse.setup/org.opendaylight.projects.setup" so I think it's using the right local one and not the stale remote one (I use a redirect), and lists all other "Repository ..." and then "Adding repository ...", except the (new) "terminal" repository and features.
Any clue what I could be missing?
Thanks!
Re: What could cause additional repository & requirement to be ignored in an existing workin [message #1736365 is a reply to message #1736354] Tue, 28 June 2016 17:24 Go to previous message
Michael,
Sorry, nothing jumps to mind. Is this change committed to master or
just to a branch and available locally? If the Open Setup opens the
resource from the workspace, the perform wizard should be using that too...
On 28.06.2016 14:19, Michael Vorburger wrote:
> Hello,
> can't get
> features.
> Thanks!
Previous Topic:Projects Build task for a subset of projects
Next Topic:problems when using Oomph with RAP
Current Time: Sat Jul 26 09:45:08 EDT 2025
Powered by FUDForum. Page generated in 0.04963 seconds
