Home » Modeling » TMF (Xtext) » Problems Using XText Language in Java project.
Problems Using XText Language in Java project. [message #1736104] Sun, 26 June 2016 02:35 Go to next message
I followed Sebastian Zarnekow's guide on how to export an XText language and use it in a standalone project.
However I'm getting the following error when attempting to validate the language:
"The string resource '_UI_DiagnosticRoot_diagnostic' could not be located"
Could it be something to do with how the JAR is exported? When exporting I chose the "Export required libraries into generated JAR", however if I use 2nd option eclipse tells me it cannot find the main class for the project.
Anyone help is appreciated Smile
Re: Problems Using XText Language in Java project. [message #1736280 is a reply to message #1736104] Tue, 28 June 2016 04:17 Go to previous messageGo to next message
Did you use the Library handling option "Package required libraries into generated JAR"? It is not the default option.
Re: Problems Using XText Language in Java project. [message #1736281 is a reply to message #1736104] Tue, 28 June 2016 04:18 Go to previous messageGo to next message
On 27/06/2016 13:57, Sam Patterson wrote:
> Hello,
> language:
> project.
> Anyone help is appreciated :)
If I remember correctly, you should export the jar with all dependencies
packed as jars into the exported jar, and NOT as extracted into the
packed jars. Otherwise the properties files and manifests will override
each others and EMF won't be able to find the properties containing the
substitutions for the strings.
hope this helps
Lorenzo
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Problems Using XText Language in Java project. [message #1736289 is a reply to message #1736281] Tue, 28 June 2016 05:31 Go to previous messageGo to next message
Yes, the option I stated above is exactly for the case that the libraries are packaged in the jar and are not unpacked. I also think that it is the failure reason.
Re: Problems Using XText Language in Java project. [message #1738010 is a reply to message #1736289] Thu, 14 July 2016 23:53 Go to previous messageGo to next message
I tried both extracting and packaging the JAR, however when I package the JAR none of the imports are recognized (mainly the XText and google ones), so I can't even run the program. However if I extract the JAR then the imports do work but of course I get the original error message.
Re: Problems Using XText Language in Java project. [message #1738071 is a reply to message #1738010] Fri, 15 July 2016 10:26 Go to previous messageGo to next message
that about simply create a valid plugin.propertties manually with the required entries ?!?
Re: Problems Using XText Language in Java project. [message #1738082 is a reply to message #1738071] Fri, 15 July 2016 11:37 Go to previous messageGo to next message
Well the problem still lies in the fact that packaging the JAR(as people stated I should be doing) causes the required imports to not be recognized, so I'm not able to get to a point where the program can be executed, therefore even if creating a plugin.properties file fixes the original '_UI_DiagnosticRoot_diagnostic error at run time, I still can't execute the application.
Re: Problems Using XText Language in Java project. [message #1738085 is a reply to message #1738082] Fri, 15 July 2016 11:43 Go to previous messageGo to next message
Please describe step by step what to do to reproduce
Re: Problems Using XText Language in Java project. [message #1738088 is a reply to message #1738085] Fri, 15 July 2016 12:36 Go to previous messageGo to next message
p.s. i did the following
(1) create a new xtext project.
(2) adapt workflow to generate java main for generator
(3) generate lang
(4) run generated java main once
(5) use the export as runnable jar file, tell it to create a ant file
(6) copy the ant file to the project
(7) adapted the ant file to include another file at the end
       		<fileset dir="${dir.workspace}/org.xtext.example.mydsl2/">
       			<include name="plugin.properties"/>
       		</fileset>
(Cool create org.xtext.example.mydsl2/plugin.properties as follows
_UI_DiagnosticRoot_diagnostic=Dont Care
well i was too lazy to look up the real values and the other key value pairs
(9) rerun ant file
(10) have fun
if id be an ant wizard i would somehow adapt the build.xml to create a plugin.properties that contains all plugin.properties of the unpacked files merged
unfortunately i am not an ant wizard
Re: Problems Using XText Language in Java project. [message #1738117 is a reply to message #1738088] Fri, 15 July 2016 15:58 Go to previous messageGo to next message
I did all the steps you mentioned above, but again the Xtext, EMF and google imports cannot be resolved.
FYI The process I'm using for adding the JAR to the standalone project is by adding it as a Library via the Build Path.
Re: Problems Using XText Language in Java project. [message #1738118 is a reply to message #1738117] Fri, 15 July 2016 16:09 Go to previous messageGo to next message
So I was able to resolve the imports but it required extracting the generated JAR file and adding all the JARs it contained to my projects build path, I'm not sure why eclipse is not reading them from the Xtext JAR.
Re: Problems Using XText Language in Java project. [message #1738122 is a reply to message #1738118] Fri, 15 July 2016 16:47 Go to previous messageGo to next message
Cause jars in jars are not allowed in java
Re: Problems Using XText Language in Java project. [message #1738130 is a reply to message #1738122] Fri, 15 July 2016 18:54 Go to previous messageGo to next message
Does that mean that I will always have to add every required JAR to the build path regardless of what export method I use for the JAR containing my DSL?
Re: Problems Using XText Language in Java project. [message #1738133 is a reply to message #1738130] Fri, 15 July 2016 22:08 Go to previous message
What I ended up doing was using the extract option and simply adding the _UI_Diagnostic line to the plugin.properties file, slightly annoying that simply trying to use a DSL in a standalone project is this troublesome, thank you for the assistance nonetheless.
Previous Topic:how to override and bind ImportUriResolver
Next Topic:Xtext Nodeutil undefined error
Current Time: Sun Nov 09 12:14:51 EST 2025
Powered by FUDForum. Page generated in 0.04385 seconds
