12+ Hour Downloads, Network failures [message #1736248] |
Mon, 27 June 2016 16:03  |
For the past two days I've been trying to install the 64-bit version of Eclipse Neon for Java developers.
First tried using the recommended installer, which seemed to freeze, then after giving up on that, tried downloading the standalone installer.
Browsers on two systems in two different physical facilities are reporting 12+ hour download times, and often report network errors with the download.
The Eclipse Neon installer version was reporting extremely long delays in downloading various components.
Is this just a case of overloaded servers with zero mirrors? I'm working on Salesforce extensions and didn't count on it being a multi-day effort just to get Eclipse installed.
Thanks for any suggestions.
Michael
Re: 12+ Hour Downloads, Network failures [message #1736309 is a reply to message #1736248] |
Tue, 28 June 2016 07:06  |
Michael,
Comments below.
By standalone installer you mean directly trying to download one of the
zipped packages?
> with the download.
The package downloads should give you a choice of mirrors. Do several
of the mirrors behave so poorly?
Yes, though it generally shows the URL of the server involved. Certainly
Neon has been well mirrored, so it should be downloading bundles
primarily from the mirrors...
There should be many mirrors for Neon.
https://www.eclipse.org/downloads/download.php?format=xml&file=/releases/neon/201606221000&countryCode=us&timeZone=1&format=xml
If the page shows empty in your browser (as it does for me with Firefox)
try "View Page Source".
If all mirrors are very slow, perhaps you're behind a corporate firewall
that's doing extensive processing (virus scanning on?) on all such
network traffic.
> Michael
FUDForum. Page generated in 0.30185 seconds
