Home » Language IDEs » PHP Development Tools (PDT) » Navigation doesn't work
Navigation doesn't work [message #1736043] Fri, 24 June 2016 10:58 Go to next message
I just downloaded PDT/Neon and I think something is missing.
- I cannot navigate inside code (Ctrl+Click or F3)
- When typing Ctrl+T I get an empty modal
- Ctrl+Shift+R works, I can navigate in files but Ctrl+Shift+T doesn't show any types.
There is no obvious errors in console.
Is that normal .
Version info
Version: Neon Release (4.6.0)
Build id: 20160613-1800
PDT 4.0.0.201606081033
(on Linux 64bits)
Re: Navigation doesn't work [message #1736054 is a reply to message #1736043] Fri, 24 June 2016 11:32 Go to previous messageGo to next message
Have you PHP project with correct buildpath?
By default PDT detects dirs with php code, and set correct build pathes.
Re: Navigation doesn't work [message #1736055 is a reply to message #1736054] Fri, 24 June 2016 11:35 Go to previous messageGo to next message
How/where do I check that ?
Re: Navigation doesn't work [message #1736056 is a reply to message #1736055] Fri, 24 June 2016 11:37 Go to previous messageGo to next message
http://help.eclipse.org/neon/topic/org.eclipse.php.help/html/tasks/configuring_build_paths.html
Re: Navigation doesn't work [message #1736057 is a reply to message #1736056] Fri, 24 June 2016 11:47 Go to previous message
I wiped out my initial import and now it works, thanks for the guidance !
Previous Topic:When I open Eclipse, no window is visible
Next Topic:PDT 4.0 released with Neon.0 !
Current Time: Tue May 13 02:18:30 EDT 2025
Powered by FUDForum. Page generated in 0.07056 seconds
