Home » Modeling » TMF (Xtext) » Rules priority xtext
Rules priority xtext [message #1735763] Wed, 22 June 2016 10:25 Go to next message
I made a grammar that provides functions and variables use. There are 2 types of functions my program will use:
First are functions developed by user in files. My rule for this function call is:
FunctionCall:
functionName=[newFunction|STR] '('(arguments+=[Assignable|STR] ',')* arguments+=[Assignable|STR] ')'
"newFunction" is a link to a function declaration rule
Second are functions directly developed in the program by me. The difference with previous rule is that the name is already definded. For example:
BarToPSI:
'BarToPSI('input=[Assignable|STR] ',' output=[Assignable|STR]')'
Here, there is no function declaration
Of course, there is a conflict between these 2 rules. Is there a way to define a priority on this ? I mean, how could I say to xtext to choose the second rule if there is a conflict ?
Re: Rules priority xtext [message #1735765 is a reply to message #1735763] Wed, 22 June 2016 10:36 Go to previous messageGo to next message
actually there is no conflict
at least not with deeper knowlege of STR rule
can you give a complete minimal grammar illustrating your problem
Re: Rules priority xtext [message #1735770 is a reply to message #1735765] Wed, 22 June 2016 10:54 Go to previous messageGo to next message
Hi Chistian,
here is a minimal version of my grammar:
Script:
instructions+=Instruction*;
Instruction:
statemement=Statement ';' |
call=FunctionCall ';'
Statement:
function=BarToMBar
BarToMBar:
'BarToMBar('input=[Assignable|STR] ',' output=[Assignable|STR]')'
FunctionCall:
CalcDeclaration returns newFunction:
'def' name=STR '('inParameters+=InVariable (',' inParameters+=InVariable )* (',' outParameters+=OutVariable)* ')' '{'
terminal STR : ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'0'..'9'|'_'|'\\')*;
ANTLR returns this to me:
warning(200): ../fr.snecma.saturne.script/src-gen/fr/snecma/saturne/script/parser/antlr/internal/InternalScript.g:1210:1: Decision can match input such as "RULE_STRING" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
warning(200): ../fr.snecma.saturne.script/src-gen/fr/snecma/saturne/script/parser/antlr/internal/InternalScript.g:3476:2: Decision can match input such as "'-'" using multiple alternatives: 1, 2
Re: Rules priority xtext [message #1735772 is a reply to message #1735770] Wed, 22 June 2016 11:11 Go to previous messageGo to next message
the grammar is not complete.
CalcDeclaration is uncalled. Assignable is undefined, same for InVariable and OutVariable
e.g.
look likely to cause this (depending on the grammar)
Re: Rules priority xtext [message #1735773 is a reply to message #1735772] Wed, 22 June 2016 11:15 Go to previous messageGo to next message
I forgot to copy this:
Script:
Instruction:
CalcDeclaration |
Statement:
function=BarToMBar
BarToMBar:
FunctionCall:
VariableDeclaration returns newVariable:
InternVariable | ExternVariable
InternVariable:
'var' name=STR '=' (value=Expression)?
ExternVariable:
'ext var' name=STR '=' (value=Expression)?
Argument returns newArgument:
InVariable | OutVariable
InVariable:
'in var' name=STR ('=' value=Expression)?
OutVariable:
'out var' name=STR ('=' value=Expression)?
Assignable:
VariableDeclaration | Argument
I think there is all rules about variables and functions Wink
Re: Rules priority xtext [message #1735775 is a reply to message #1735773] Wed, 22 June 2016 11:23 Go to previous messageGo to next message
first one tipp: never use spaces in keyword 'a b' => 'a' 'b'
then there is expression missing in your grammar.
so can you create a new project and try the grammar there to get a minimal reproducing example
Re: Rules priority xtext [message #1735778 is a reply to message #1735775] Wed, 22 June 2016 11:31 Go to previous messageGo to next message
Well, Expression is almost the rest of my grammar (very big)
For information, all my grammar worked fine before I add this line:
BarToMBar:
Assignable is only used by BarToMBar and FunctionCall
Re: Rules priority xtext [message #1735779 is a reply to message #1735778] Wed, 22 June 2016 11:36 Go to previous message
as i said: when i cannot reproduce this i cannot tell
setting
Expression value=ID does not help to make it fail.
did you have a look at the generated antlr file in the lines
1210 and 3476
it is complaining about "-" and the STRING rule which both are not used in what you posted
Previous Topic:Using forEach correctly
Next Topic:port existing Eclipse Plugin to Intellij
Current Time: Sat Jul 26 22:13:14 EDT 2025
Powered by FUDForum. Page generated in 0.04680 seconds
