Home » Newcomers » Newcomers » Regexp MULTILINE mode to find & delete a multi line XML stanza
Regexp MULTILINE mode to find & delete a multi line XML stanza [message #1735506] Mon, 20 June 2016 09:44 Go to next message
I have a lot of XML configuration files where I need to remove the following....
<filteredResources>
<filter>
<id>1396938000000</id>
<name></name>
<type>10</type>
<matcher>
<id>org.eclipse.ui.ide.multiFilter</id>
<arguments>1.0-projectRelativePath-matches-true-false-target</arguments>
</matcher>
</filter>
</filteredResources>
As per the help text of the find dialog
http://download.oracle.com/javase/6/docs/api/java/util/regex/Pattern.html
is the implementation engine of Eclipse find.
With Regular expression checked, all of the following find "Containing text:" string have not worked.
<filteredResources>.+<\/filteredResources>(?m).
(?m).<filteredResources>.+<\/filteredResources>
My guess is that since the XML stanza covers more than one line I need to turn on MULTILINE mode.
http://docs.oracle.com/javase/6/docs/api/java/util/regex/Pattern.html#MULTILINE
I found this little explanation, and came up with the following "Containing text", but it does not work either.
(?m)<filteredResources>.++$(\r\n?|\n)^.*+$(\r\n?|\n)^<\/filteredResources>
But it does not seem to be working. What is the proper way to use the
(?m).
token in the find string?
[Updated on: Mon, 20 June 2016 10:01] by Moderator
Re: Regexp MULTILINE mode to find &amp; delete a multi line XML stanza [message #1735594 is a reply to message #1735506] Tue, 21 June 2016 07:20 Go to previous messageGo to next message
That ought to work, but doesn't it seem to work. I'm not sure why. This
however seems to work and handles both Windows and Linux line feeds.
<filteredResources>(.|[\n\r])+</filteredResources>
> following....
> <filteredResources>
> <filter>
> <name></name>
> <type>10</type>
> <matcher>
> </matcher>
> </filter>
> (?m).
Re: Regexp MULTILINE mode to find &amp; delete a multi line XML stanza [message #1735601 is a reply to message #1735594] Tue, 21 June 2016 07:42 Go to previous messageGo to next message
Windows 7
Mars2
Confirmed works for me too.
Thanks Ed.
Re: Regexp MULTILINE mode to find &amp; delete a multi line XML stanza [message #1735649 is a reply to message #1735594] Tue, 21 June 2016 11:18 Go to previous message
I submitted a report.
Bug 496484 - Multiline search (?m) does not work.
[Updated on: Tue, 21 June 2016 11:18] by Moderator
Previous Topic:Viewing all attributes in the outline window
Next Topic:Java class files for tomcat, where?
Current Time: Mon Jul 21 09:20:20 EDT 2025
Powered by FUDForum. Page generated in 0.14954 seconds
