Home » Archived » Buckminster » Buckminster ->Jenkins: Unable to load repositories (Jenkins build is unable to load repositories )
icon8.gif  Buckminster ->Jenkins: Unable to load repositories [message #1735299] Fri, 17 June 2016 03:50 Go to next message
I am trying to build this project on jenkins with buckminster plugin. The buckminster build is working perfectly in my Eclipse but on Jenkins it gives the following errors.
Installation failed, Unable to load repositories.
i have attached the jenkins console output .
download.Cloudsmith.com is down . Is there any alternate mirror site.
  • Attachment: jenkins.JPG
    (Size: 221.02KB, Downloaded 543 times)
  • Attachment: LOG.log
    (Size: 22.42KB, Downloaded 203 times)
[Updated on: Mon, 20 June 2016 09:11] by Moderator
Re: Buckminster ->Jenkins: Unable to load repositories [message #1735478 is a reply to message #1735299] Mon, 20 June 2016 05:45 Go to previous messageGo to next message
The RC=13 usually indicates a problem with dependencies. What makes you think that download.Cloudsmith.com is down?
Can you attach the full log please, and as a text file, not as an image. What you originally posted is not enough to understand the problem.
Re: Buckminster ->Jenkins: Unable to load repositories [message #1735479 is a reply to message #1735478] Mon, 20 June 2016 05:49 Go to previous messageGo to next message
Hmm ... I notice that there is another thread with the title "problems with http://download.cloudsmith.com", so you might want to keep an eye on that also. No solution offered as yet.
Re: Buckminster ->Jenkins: Unable to load repositories [message #1735481 is a reply to message #1735479] Mon, 20 June 2016 05:52 Go to previous messageGo to next message
Another idea - which components are you trying to download from cloudsmith? Do you actually need them? For example, if you're not using Subclipse, then you don't need to get the Buckminster Subclipse adapter from cloudsmith.
Re: Buckminster ->Jenkins: Unable to load repositories [message #1735504 is a reply to message #1735481] Mon, 20 June 2016 09:16 Go to previous messageGo to next message
Hallo Matthew,
Thank you very much for your reply, I have attached the log,
I have tried to open the Cloudsmith link in browser and it gave me 404 error.
I actually used the standard JSON file from this Link. I will remove the cloudsmith part and see if it works.
http://updates.jenkins-ci.org/updates/hudson.plugins.buckminster.BuckminsterInstallation.BuckminsterInstaller.json
[Updated on: Mon, 20 June 2016 09:25] by Moderator
Re: Buckminster ->Jenkins: Unable to load repositories [message #1735771 is a reply to message #1735504] Wed, 22 June 2016 11:09 Go to previous message
I think you need to fix this first:
!MESSAGE Connection to http://download.eclipse.org/tools/buckminster/headless-4.2/p2.index failed on download.eclipse.org. Retry attempt 0 started
!STACK 0
java.net.UnknownHostException: download.eclipse.org
UnknownHostException?? Doesn't that suggest that there is something wrong with the setup on your Jenkins machine? Proxy maybe?
Another observation: We use Buckminster in Jenkins, but we don't use the Buckminster plugin - we just run buckminster in a regular shell step. To be honest, I'm not sure whether the Buckminster plugin is maintained - the last release was 3 years ago.
Previous Topic:problems with http://download.cloudsmith.com
Next Topic:news.eclipse.org is shutting down.
Current Time: Mon Jul 21 01:18:55 EDT 2025
Powered by FUDForum. Page generated in 0.25948 seconds
