Home » Eclipse Projects » Plugin Development Environment (PDE) » Suppress the warning that there is no 'target/' directory?
Suppress the warning that there is no 'target/' directory? [message #1735415] Sat, 18 June 2016 18:27 Go to next message
Is there a way to suppress the warning that there is no 'target/' directory? I have configured my '.project' file to ignore the target directory. Using the following XML stanza in the '.project' file.
<filteredResources>
<filter>
<id>1396938000000</id>
<name></name>
<type>10</type>
<matcher>
<id>org.eclipse.ui.ide.multiFilter</id>
<arguments>1.0-projectRelativePath-matches-true-false-target</arguments>
</matcher>
</filter>
</filteredResources>
index.php/fa/26209/0/
But I still get the warning.
  • Attachment: Snap1.png
    (Size: 29.21KB, Downloaded 655 times)
[Updated on: Sat, 18 June 2016 18:27] by Moderator
Re: Suppress the warning that there is no 'target/' directory? [message #1735416 is a reply to message #1735415] Sat, 18 June 2016 18:38 Go to previous messageGo to next message
Well the question is why is that in your build.properties?
By default a plugin has no entry out..
Tom
> <filteredResources>
> <filter>
> <name></name>
> <type>10</type>
> <matcher>
> </matcher>
> </filter>
Re: Suppress the warning that there is no 'target/' directory? [message #1735417 is a reply to message #1735416] Sat, 18 June 2016 18:42 Go to previous messageGo to next message
Because I am using Tycho. 'target/' is the default for output.
Re: Suppress the warning that there is no 'target/' directory? [message #1735468 is a reply to message #1735417] Mon, 20 June 2016 03:25 Go to previous message
Maven has target as output but tycho is using the build.properties. So
you don't need out..!
Tom
Previous Topic:How to add the fragment feature to update site
Next Topic:create custom export wizard
Current Time: Sat Aug 02 09:55:04 EDT 2025
Powered by FUDForum. Page generated in 0.10582 seconds
