Home » Modeling » Epsilon » Eunit JunitClasses missing in jars?
Eunit JunitClasses missing in jars? [message #1735309] Fri, 17 June 2016 05:47 Go to next message
i want to implement some Junit tests according to the example given at your website:
http://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.eunit.examples.junit
However i cannot find the used classes (EUnitTestRunner, IEUnitSuite) from the package org.eclipse.epsilon.eunit.junit
anywhere in the jars.
Am I missing something or is this no longer supported?
Greetings
Sebastian
[Updated on: Fri, 17 June 2016 05:48] by Moderator
Re: Eunit JunitClasses missing in jars? [message #1735316 is a reply to message #1735309] Fri, 17 June 2016 06:51 Go to previous messageGo to next message
These classes still exist and are part of the eunit.junit plugin, which is part of the core.dt feature (Core Development Tools). However, they're not in the standalone JARs, since internally they use some Eclipse components. I could split off the Eclipse-specific bits, however, if that's what you need. Would that work for you?
[Updated on: Fri, 17 June 2016 06:52] by Moderator
Re: Eunit JunitClasses missing in jars? [message #1735331 is a reply to message #1735316] Fri, 17 June 2016 08:14 Go to previous messageGo to next message
Hi Antonio, thx for the quick answer.
That would be great. I have several Eunit Test that i'd like to include in my continuous integration.
For now i copied the files from the source code in to my project and removed the few parts, that require eclipse specific classes.
Maybe you can answer another question. In the example you define your own operation contributor with a method.
public void transform() throws Exception {
    EtlModule etl = new EtlModule();
    etl.getContext().setModelRepository(context.getModelRepository());
    etl.parse(new File("resources/etl/Tree2Graph.etl"));
    etl.execute();
I don't understand exactly when and by whom this method will be executed. Could you please explain this?
[Updated on: Fri, 17 June 2016 08:28] by Moderator
Re: Eunit JunitClasses missing in jars? [message #1739284 is a reply to message #1735331] Fri, 29 July 2016 06:47 Go to previous messageGo to next message
Sorry for the delay: I didn't receive any notifications regarding your edit :-/.
You can call this operation from anywhere in the EOL file: see all the "transform();" calls in the .eunit file?
Essentially, operation contributors allow you to add methods to an object through Java reflection. If you always return true in the contributesTo, you'll add the method to anything, including the special EolNoType value that is used for context-less calls (e.g. "transform();" is contextless, "a.transform();" is not).
Re: Eunit JunitClasses missing in jars? [message #1739293 is a reply to message #1739284] Fri, 29 July 2016 08:43 Go to previous message
By the way, the split is now complete, so you can use EUnitTestRunner from the core .jar [1]. The Eclipse-specific bit is in the EclipseEUnitTestRunner, not part of the standalone distro.
[1]: https://bugs.eclipse.org/bugs/show_bug.cgi?id=498879
Previous Topic:[Eugenia] Sub-labels into nodes and links
Next Topic:EObject type in Epsilon
Current Time: Fri Jul 18 13:57:06 EDT 2025
Powered by FUDForum. Page generated in 0.07479 seconds
