Home » Eclipse Projects » NatTable » column with by percent and group column header
column with by percent and group column header [message #1735240] Thu, 16 June 2016 10:26 Go to next message
I was using the setColumnWidthByPosition to set the percentage of the
column. BodyDataLayer.setColumnPercentageSizing(true) is set as well.
since I am using a group column header layer the
setColumnWidthByPosition does not have an effect.
Is this intended or may I have missed change some thing else while
adding the ColumnGroupLayer?
Any hints are appreciated, Martin
Re: column with by percent and group column header [message #1735243 is a reply to message #1735240] Thu, 16 June 2016 10:51 Go to previous messageGo to next message
Not sure. Typically the column header gets its width derived from the body. I suspect the column group header should get its column widths derived from the column header.
Are you setting the column width on the column group header or the body? Not sure where which communication might not be passed accordingly.
Re: column with by percent and group column header [message #1735294 is a reply to message #1735243] Fri, 17 June 2016 03:13 Go to previous messageGo to next message
Good Morning,
thanks Dirk. The column width is set at the BodyDataLayer only.
Please the implementation of the BodyLayerStack below:
class BodyLayerStack extends AbstractLayerTransform {
private SelectionLayer mSelectionLayer;
private DataLayer mBodyDataLayer;
public BodyLayerStack(BodyDataProvider dataProvider) {
mBodyDataLayer = new DataLayer(dataProvider);
mBodyDataLayer.setColumnPercentageSizing(true);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.X_AXIS.getValue(), 5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.ITEMS_INFRA.getValue(),
9);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.SHOW_H_LINES.getValue(),
5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y11_AXIS.getValue(), 5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y11_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y11_AVG_FUNCTION_TYPE.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y11_COMPARATOR_FUNCTION_TYPE.getValue(),
5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y12_AXIS.getValue(), 5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y12_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y12_AVG_FUNCTION_TYPE.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y21_AXIS.getValue(), 5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y21_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y21_AVG_FUNCTION_TYPE.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y22_AXIS.getValue(), 5);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y22_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthByPosition(ColumnIndex.Y22_AVG_FUNCTION_TYPE.getValue(),
7);
mSelectionLayer = new SelectionLayer(mBodyDataLayer);
ViewportLayer viewportLayer = new ViewportLayer(mSelectionLayer);
setUnderlyingLayer(viewportLayer);
public SelectionLayer getSelectionLayer() {
return mSelectionLayer;
public DataLayer getBodyDataLayer() {
return mBodyDataLayer;
as well as the ColumnHeaderLayerStack
class ColumnHeaderLayerStack extends AbstractLayerTransform {
private ColumnHeaderLayer mColHeaderLayer;
private ColumnGroupHeaderLayer mColumnGroupHeaderLayer;
public ColumnHeaderLayerStack(IDataProvider dataProvider,
BodyLayerStack pBodyLayer) {
DataLayer dataLayer = new DataLayer(dataProvider);
mColHeaderLayer = new ColumnHeaderLayer(dataLayer, pBodyLayer,
pBodyLayer.getSelectionLayer());
ColumnGroupModel lColumnGroupModel = new ColumnGroupModel();
mColumnGroupHeaderLayer = new ColumnGroupHeaderLayer(mColHeaderLayer,
pBodyLayer.getSelectionLayer(), lColumnGroupModel);
mColumnGroupHeaderLayer.addColumnsIndexesToGroup(_("X Axis"),
ColumnIndex.X_AXIS.mValue, ColumnIndex.ITEMS_INFRA.mValue,
ColumnIndex.SHOW_H_LINES.mValue);
mColumnGroupHeaderLayer.setGroupUnbreakable(1);
mColumnGroupHeaderLayer.addColumnsIndexesToGroup(_("Y Axis Primary
1"), ColumnIndex.Y11_AXIS.mValue, ColumnIndex.Y11_ITEMS_VALUES.mValue,
ColumnIndex.Y11_AVG_FUNCTION_TYPE.mValue,
ColumnIndex.Y11_COMPARATOR_FUNCTION_TYPE.mValue);
mColumnGroupHeaderLayer.setGroupUnbreakable(2);
2"), ColumnIndex.Y12_AXIS.mValue, ColumnIndex.Y12_ITEMS_VALUES.mValue,
ColumnIndex.Y12_AVG_FUNCTION_TYPE.mValue);
mColumnGroupHeaderLayer.setGroupUnbreakable(3);
mColumnGroupHeaderLayer.addColumnsIndexesToGroup(_("Y Axis Secondary
1"), ColumnIndex.Y21_AXIS.mValue,
ColumnIndex.Y21_ITEMS_VALUES.mValue,
ColumnIndex.Y21_AVG_FUNCTION_TYPE.mValue);
mColumnGroupHeaderLayer.setGroupUnbreakable(4);
2"), ColumnIndex.Y22_AXIS.mValue,
ColumnIndex.Y22_ITEMS_VALUES.mValue,
ColumnIndex.Y22_AVG_FUNCTION_TYPE.mValue);
mColumnGroupHeaderLayer.setGroupUnbreakable(5);
setUnderlyingLayer(mColHeaderLayer);
public ColumnGroupHeaderLayer getColumnGroupHeaderLayer() {
return mColumnGroupHeaderLayer;
Do you see any thing suspicious?
Thanks, Martin
Re: column with by percent and group column header [message #1735297 is a reply to message #1735294] Fri, 17 June 2016 03:32 Go to previous messageGo to next message
Why don't you set mColumnGroupHeaderLayer as underlying layer of your column header layer stack?
Re: column with by percent and group column header [message #1735307 is a reply to message #1735297] Fri, 17 June 2016 05:18 Go to previous messageGo to next message
Sorry, I forgot to replace when I was adding the ColumnGroupHeaderLayer.
I use now setUnderlyingLayer(mColumnGroupHeaderLayer); but the issues
still exist :(
Modified code ColumnHeaderLayerStack:
Re: column with by percent and group column header [message #1735319 is a reply to message #1735307] Fri, 17 June 2016 07:00 Go to previous messageGo to next message
Have you tried to call setColumnWidthPercentageByPosition() instead of setColumnWidthByPosition()?
And please use the code formatting for posting code. It is very hard to read your code postings as simple text.
Re: column with by percent and group column header [message #1735332 is a reply to message #1735319] Fri, 17 June 2016 08:10 Go to previous messageGo to next message
Thanks Dirk,
yes setColumnWidthPercentageByPosition() works fine! :)
So I removed mBodyDataLayer.setColumnPercentageSizing(true); and call
Sorry to not format as source code. I am using thunderbird as forum
client and I am no sure how to format in code.
My login for the newsgroup unfortunately does not allow me to login to
use the web front end.
May be using html tags?
<code>
</code>
Re: column with by percent and group column header [message #1735337 is a reply to message #1735332] Fri, 17 June 2016 08:38 Go to previous messageGo to next message
instead of the HTML tag syntax with the lower and greater than signs, you should use []
Re: column with by percent and group column header [message #1735339 is a reply to message #1735337] Fri, 17 June 2016 08:42 Go to previous message
here the solution code:
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.X_AXIS.getValue(),
5);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.SHOW_H_LINES.getValue(),
5);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y11_AXIS.getValue(),
4);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y11_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y11_AVG_FUNCTION_TYPE.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y11_COMPARATOR_FUNCTION_TYPE.getValue(),
3);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y12_AXIS.getValue(),
4);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y12_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y12_AVG_FUNCTION_TYPE.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y21_AXIS.getValue(),
4);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y21_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y21_AVG_FUNCTION_TYPE.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y22_AXIS.getValue(),
4);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y22_ITEMS_VALUES.getValue(),
7);
mBodyDataLayer.setColumnWidthPercentageByPosition(ColumnIndex.Y22_AVG_FUNCTION_TYPE.getValue(),
7);
Previous Topic:Copy/paste from external source
Next Topic:Nattable with "horizontal tree" structure
Current Time: Fri Jul 25 08:47:41 EDT 2025
Powered by FUDForum. Page generated in 0.07673 seconds
