Highlight edges when selecting a node [message #1735204] |
Thu, 16 June 2016 06:18  |
I had a question about the highlight of connected edges when selecting the node. If I select a node, so I would like to highlight (selected) all edges that are connected to the node.
On the attached picture you can see that when you select a node TST001_U002 are selected and connected edges. Ideally, still change the color of edges connected (but not necessary).
Can this be done?
Thanks so much for any advice.
Martin
Re: Highlight edges when selecting a node [message #1735223 is a reply to message #1735204] |
Thu, 16 June 2016 09:07   |
That is a nice idea, especially on big diagrams. The highlighting is
managed by
org.eclipse.sirius.diagram.ui.graphical.edit.policies.SiriusGraphicalNodeEditPolicy.addHighlight().
You will have to provide your own EditPart[1] in order to install your
own EditPolicy overriding ours. In createDefaultEditPolicies, you should
have something like
self.installEditPolicy(EditPolicy.GRAPHICAL_NODE_ROLE, new
SuperCoolHighligthingSiriusGraphicalNodeEditPolicy());
Note that in your EditPolicy you will have to override the
showTargetConnectionFeedback method. The method addHighlight is private
but you will have your own implementation anyway.
Steve
[1]https://www.eclipse.org/sirius/doc/developer/extensions-provide_custom_style.html
Le 16/06/2016 à 12:18, Martin Jedlicka a écrit :
> Hello,
> Can this be done?
> Martin
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Highlight edges when selecting a node [message #1735225 is a reply to message #1735204] |
managed by
have something like
Steve
> Hello,
> Can this be done?
> Martin
Re: Highlight edges when selecting a node [message #1735310 is a reply to message #1735223] |
Fri, 17 June 2016 05:47  |
I think that the policy proposed by Steve is not the only one that can
be used. In Sirius, we already done something smiliar. When you select
an edge, the edge label is "highlighted" (and conversely). This is done
in [1] and [2].
This is another entry point.
[1]
org.eclipse.sirius.diagram.ui.graphical.edit.policies.AbstractEdgeSelectionFeedbackEditPolicy.createSelectionHandles()
[2]
org.eclipse.sirius.diagram.ui.graphical.edit.policies.DEdgeSelectionFeedbackEditPolicy.createSelectionHandles()
Laurent
Le 16/06/2016 à 15:07, Steve Monnier a écrit :
> Hello,
> managed by
> have something like
> Regards,
> Steve
>> Hello,
>> Can this be done?
>> Martin
Laurent Redor - Obeo
FUDForum. Page generated in 0.06608 seconds
