Home » Newcomers » Newcomers » Eclipse marketplace unavailable on Mars
Eclipse marketplace unavailable on Mars [message #1735191] Thu, 16 June 2016 05:00 Go to next message
On Eclipse Mars 4.5.2, running under Ubuntu, I cannot see
Help > Eclipse Marketplace
menu item.
Why ? How could I make it appear ?
Thanks.
Re: Eclipse marketplace unavailable on Mars [message #1735201 is a reply to message #1735191] Thu, 16 June 2016 06:08 Go to previous messageGo to next message
The menus can be customized in the perspective settings.
Click: Window -> Perspective -> Customize Perspective ... -> Menu Visibility -> Help
and check if the Marketplace item is set visible.
Re: Eclipse marketplace unavailable on Mars [message #1735229 is a reply to message #1735201] Thu, 16 June 2016 09:14 Go to previous messageGo to next message
Thanks, but unfortunately this item is not available at the place you mention, either.
[Updated on: Thu, 16 June 2016 09:15] by Moderator
Re: Eclipse marketplace unavailable on Mars [message #1735241 is a reply to message #1735229] Thu, 16 June 2016 10:50 Go to previous messageGo to next message
Did you use the Eclipse installer to set up Eclipse?
Re: Eclipse marketplace unavailable on Mars [message #1735270 is a reply to message #1735241] Thu, 16 June 2016 14:44 Go to previous messageGo to next message
Not sure.
Re: Eclipse marketplace unavailable on Mars [message #1735411 is a reply to message #1735270] Sat, 18 June 2016 13:07 Go to previous messageGo to next message
Anybody has any idea as to how make Eclipse MarketPlace available within Eclipse menu ??
Re: Eclipse marketplace unavailable on Mars [message #1735429 is a reply to message #1735411] Sun, 19 June 2016 06:58 Go to previous messageGo to next message
How did you create your installation? Which package did you install?
Re: Eclipse marketplace unavailable on Mars [message #1735431 is a reply to message #1735429] Sun, 19 June 2016 08:16 Go to previous messageGo to next message
Well, I am not sure, I installed Luna at the time it appeared, don't remind exactly how I did get the Mars version, by automatic update or installing the package on the Eclipse site. Anyway I did not compile Eclipse on my own.
EDIT If that may help, here is my Eclipse config.ini
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Tue Apr 05 08:54:47 CEST 2016
org.eclipse.update.reconcile=false
eclipse.p2.profile=SDKProfile
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.10.102.v20160118-1700.jar
equinox.use.ds=true
eclipse.buildId=4.5.2.M20160212-1500
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.1.100.v20150423-1455.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=org.eclipse.sdk.ide
osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.compatibility.state_1.0.100.v20150402-1551.jar,reference\:file\:org.eclipse.fx.osgi_2.1.0.201508240501.jar
eclipse.p2.data.area=@config.dir/../p2/
eclipse.application=org.eclipse.ui.ide.workbench
osgi.bundles.defaultStartLevel=4
[Updated on: Sun, 19 June 2016 08:22] by Moderator
Re: Eclipse marketplace unavailable on Mars [message #1735433 is a reply to message #1735431] Sun, 19 June 2016 08:47 Go to previous messageGo to next message
So you're probably best to use the installer to install a brand new Mars
version of some package or download one of the Mars packages and
unzip/package it to a new location. Or wait until Wednesday and do
those same things, but get the Neon version. Failing that, it's hard for
anyone to comment informatively on why your
Luna-that's-somehow-become-Mars installation doesn't show the market
place options.
> Eclipse on my own.
Re: Eclipse marketplace unavailable on Mars [message #1735434 is a reply to message #1735431] Sun, 19 June 2016 08:56 Go to previous messageGo to next message
From what I understand. The Marketplace requires that the Eclipse
Marketplace Client is installed. I don't know if all of the Eclipse
download packages include this feature. You may have downloaded a
package that doesn't have the client prepackaged. You should be able to
install the client by going to Install New Software, selecting the
update site for you Eclipse release and searching for Market Place Client.
If it is installed, it should show up the Features tab of your
Installation Details dialog with the name Eclipse Marketplace Client
Re: Eclipse marketplace unavailable on Mars [message #1735438 is a reply to message #1735433] Sun, 19 June 2016 09:47 Go to previous messageGo to next message
Thanks. I shall wait for the Neon version.
Re: Eclipse marketplace unavailable on Mars [message #1735439 is a reply to message #1735434] Sun, 19 June 2016 09:52 Go to previous message
The default Mars installation (Java and/or CDT) set up by the installer does install Marketplace Client.
I have Mars in Kubuntu (several versions), installed with the installer, and it does have the marketplace.
The OP's installation may be fishy, and if I were him, I'd export the installation list to a .p2f file, discard the current installation and start downloading Eclipse Mars Installer. It can be used to install some base system (e.g. Java or CDT) and import the remaining modules using the exported .p2f file.
Previous Topic:Create GMF Project, Acceleo plugins or Stand Alone
Next Topic:UNABLE TO DOWNLOAD SOFTWARE THROUGH ECLIPSE MARKETPLACE
Current Time: Wed Jul 23 17:40:57 EDT 2025
Powered by FUDForum. Page generated in 0.10242 seconds
