isFactoryForType implementation guideline for adapter factories used by AdapterFactoryContentProvide [message #1734929] |
Mon, 13 June 2016 16:04  |
Hi all
I want to register adapter factories that provide adapters from EMF objects defined in multiple model packages to jface content and label providers.
Guided by http://help.eclipse.org/juno/topic/org.eclipse.emf.doc/references/overview/EMF.Edit.html I configure a TreeViewer with an AdapterFactoryContentProvider and an AdapterFactoryLabelProvider, which are initialized with a ComposedAdapterFactory.
I learned that the framework calls the isFactoryForType method for each registered AdapterFactory multiple times to decide whether the adapter factory can provide a suitable adapter or not.
The javadoc is not to clear about what is tested there, i.e. to which set of type objects the adapter is expected to conform.
For example, there are package objects being supplied as input types but it is unclear for me for what reasons.
Moreover, I learned that if multiple adapter factories conform to a specific set of calls to isFactoryForType, just the first adapter factory will be used to provide adapters.
What are the rules of how the isFactoryForType is used by the framework (specifically the ComposedAdapterFactory and the AdapterFactory[Content|Label]Provider setup)?
How are the isFactoryForType methods to be implemented if multiple adapter factories for multiple EMF models (packages) are to be registered?
Greetings
Thilo
Re: isFactoryForType implementation guideline for adapter factories used by AdapterFactoryContentPro [message #1735089 is a reply to message #1734929] |
Wed, 15 June 2016 09:34   |
Thilo,
Comments below.
On 14.06.2016 15:57, Thilo Bohr wrote:
> Hi all
> providers.
> Guided by
A common idiom is to use
new
ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE)
This way all registered item provide adapter factories will be used as
needed. You can add specialized adapter factories to this composed one
to override registered ones...
It's a rather plastic API.
To find the specific item provider adapter factory for that package.
Yes, the list is searched sequentially.
The most important method is
org.eclipse.emf.edit.provider.ComposedAdapterFactory.getFactoryForTypes(Collection<?>)
for selecting an adapter factory to use. And that's driven from
org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(Notifier,
Object, boolean) which needs to create an adapter.
> registered?
You can look at generated implementations and you can use the debugger
to answer very detailed questions. The general idea is that given an
object of some type T (and that type is from some package P) and the
desire to create an adapter of some type X, you need to find a factory
that can create adapters of type X for typed T from P so that's why you
see isFactoryForType being called with X and P (with the later being the
case because a factory is registered on a per-package basis).
> Greetings
> Thilo
FUDForum. Page generated in 0.08103 seconds
