Detecting the end of validation? [message #1735062] |
Wed, 15 June 2016 03:20  |
In my xbase project, I'm doing some custom tracking of resources which have been "affected" between build cycles.
I then query this tracking in a custom extension of DerivedStateAwareResourceDescriptionManager.isAffected() which is called repeatedly during the validation cycle.
My question is, how can I detect that such a cycle is complete so that I can clear my tracking? I've tried tracing the calls to the method, but I haven't been able to find a clear hook to trace when validation or build is complete.
For example, when I edit a file in my project and then save, I see a full validation run, along with a number of calls to isAffected() for the given deltas. How can I detect when this series of calls is complete?
Thanks!
[Updated on: Wed, 15 June 2016 03:20] by Moderator
Re: Detecting the end of validation? [message #1736806 is a reply to message #1736683] |
Fri, 01 July 2016 20:26  |
Great, thanks for the hooks! I'll look into all of your suggestions.
My language has unfortunately complex cross-referencing where one "method call" can refer to many "methods". (one-to-many). At runtime, the potential-matching methods are all placed in a list and the actual method to run is chosen procedurally (based on system state and possibly randomness).
So, because of this, I need to do my own tracking of cross-references and affected resources, to make sure everything is properly rebuilt when needed. If there's another way, I'm all ears!
FUDForum. Page generated in 0.03303 seconds
