Home » Eclipse Projects » Eclipse Scout » [neon] [oomph] import Demo app - auth failed
[neon] [oomph] import Demo app - auth failed [message #1734977] Tue, 14 June 2016 07:11 Go to next message
I did some "playing around with Oomph".
Using Eclipse Neon RC3 I've created a fresh workspace and tried the following:
1. File - Import...
2. Oomph - Projects into Workspace
3. selected "Eclipse Projects - Scout - Scout Demo App"
installation process started, IDE restarted and afterwards I've got the following error:
Performing Git Clone git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git  (features/neon_rc1)
Cloning Git repo git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git to /xxx/eclipse.neon.rc3/git/org.eclipse.scout.docs
Updating indexes
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Auth fail
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:821)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3021)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2964)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4160)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4154)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4152)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2955)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2930)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2861)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:555)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:681)
Caused by: org.eclipse.jgit.api.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Auth fail
  at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:135)
  at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:202)
  at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:135)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.cloneRepository(GitCloneTaskImpl.java:877)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:746)
  ... 1 more
Caused by: org.eclipse.jgit.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Auth fail
  at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:159)
  at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:137)
  at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:264)
  at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:162)
  at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
  at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
  at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1179)
  at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:128)
  ... 2 more
Caused by: com.jcraft.jsch.JSchException: Auth fail
  at com.jcraft.jsch.Session.connect(Session.java:512)
  at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:116)
  ... 3 more
any idea?
Re: [neon] [oomph] import Demo app - auth failed [message #1734995 is a reply to message #1734977] Tue, 14 June 2016 10:07 Go to previous message
I think it is better to discuss it on the Oomph Forum.
I have cross-posted your question and answered it there:
https://www.eclipse.org/forums/index.php/m/1734993/#msg_1734993
Previous Topic:[Blog Post] Scout Neon: Display the Keys for the Localized Texts in your Application
Next Topic:[neon] Problems spacing buttons in group box
Current Time: Sat Sep 13 11:06:57 EDT 2025
Powered by FUDForum. Page generated in 0.03813 seconds
