Home » Eclipse Projects » EGit / JGit » Delete a repo after cloning
Delete a repo after cloning [message #1734656] Fri, 10 June 2016 04:14 Go to next message
i am currently trying to implement a tool using JGit that accesses a certain file from a remote GIT repo and cleans up its own check right after.
I am using the following code to get a clone of repo to my local disk:
CloneCommand gitclone=new CloneCommand();
gitclone.setURI(baseurl);
gitclone.setDirectory(tempdir.toFile());
Git git=gitclone.call()
Then once i have aquired the file contents i am trying to get rid of the repo by calling
git.close();
git=null;
and then doing a recurisve delete on tempdir (using a Java 8 File.walkFIleTree
Unfortunately that cleanup action fails to delete some files as they still seem to be open.
Anyone with a suggestion how to achieve a proper cleanup of the created repo clone?
Markus
Re: Delete a repo after cloning [message #1734801 is a reply to message #1734656] Sun, 12 June 2016 18:39 Go to previous messageGo to next message
Markus,
depending on which version of JGit you use, you may have run into this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=474093
HTH
Rüdiger Herrmann
http://codeaffine.com
On 10.06.2016 20:03, Markus Kramer wrote:
> after.
> repo by calling
> git.close();
> git=null;
> File.walkFIleTree
> still seem to be open. Anyone with a suggestion how to achieve a proper
> Markus
Re: Delete a repo after cloning [message #1734992 is a reply to message #1734801] Tue, 14 June 2016 10:03 Go to previous messageGo to next message
I don't think that's related to problems mentioned in https://bugs.eclipse.org/bugs/show_bug.cgi?id=474093 . I tried it on my windows box: If you don't close the Git instance you can't delete all files. But if you close the instance you can the delete the File hierarchy with java.io.File methods, but not with java.nio.file.FileTreeWalker. I have no explanation why. But deleting with java.io.File seems to be a workaround.
This code works
	public static void main(String args[])
			throws IOException, GitAPIException, JGitInternalException, InterruptedException {
		File tmpDir = new File(System.getProperty("java.io.tmpdir"),
				"JGitTest_CloneBranchExample_" + System.currentTimeMillis());
		tmpDir.mkdirs();
		System.out.println("Working dir: " + tmpDir);
		try (Git r = Git.cloneRepository().setDirectory(tmpDir).setURI("https://github.com/chalstrick/dondalfi.git")
				.call()) {
			System.out.println("HEAD: " + r.log().call().iterator().next());
		rm(tmpDir);
	static void rm(File f) {
		if (f.isDirectory())
			for (File c : f.listFiles())
				rm(c);
		if (!f.delete())
			System.err.println("Couldn't delete file " + f);
But this code doesn't work:
	public static void main(String args[]) throws IOException, GitAPIException, JGitInternalException, InterruptedException {
		tmpDir.mkdirs();
				.call()) {
		Files.walkFileTree(tmpDir.toPath(), new SimpleFileVisitor<Path>() {
			public FileVisitResult visitFile(Path file, BasicFileAttributes attrs) throws IOException {
				Files.delete(file);
				return FileVisitResult.CONTINUE;
			public FileVisitResult postVisitDirectory(Path dir, IOException exc) throws IOException {
				Files.delete(dir);
Re: Delete a repo after cloning [message #1734997 is a reply to message #1734992] Tue, 14 June 2016 10:11 Go to previous messageGo to next message
Another thing I tried with the non-working code of the previous post: I started the non-working code with http://file-leak-detector.kohsuke.org/ in order to find out whether some of our code still has a file handle open ... nope. All file handles to pack/index files are closed and still we are getting a AccessDeniedException when trying to delete the index file with java.nio. And java.io can delete it. That's strange.
Re: Delete a repo after cloning [message #1735100 is a reply to message #1734997] Wed, 15 June 2016 10:26 Go to previous messageGo to next message
Thanks a lot for your help, it is indeed confusing that this is dependent on the delete method applied, which i did not yet try but consider a valid workaround for my use case.
I also tried actually deleting that repo from Windows Explorer which also rejected deletion while the Java VM with the WebApplication that did the Clone was still running. As soon as i killed the JVM Windows Explorer was able to delete stuff right away.
Markus
Re: Delete a repo after cloning [message #1735186 is a reply to message #1735100] Thu, 16 June 2016 04:23 Go to previous message
Really, that's an interesting outcome. If it is really the case that Windows Explorer can't delete a folder hierarchy but java.io.File methods can this would be a surprise and worth looking into it deeper. I'll try
Previous Topic:How to Create a Note for a BLOB Object?
Next Topic:Change a commit message or timestamop
Current Time: Sat Jul 26 00:33:30 EDT 2025
Powered by FUDForum. Page generated in 0.03766 seconds
