Home » Modeling » TMF (Xtext) » Bundle Exception - Error when launching Eclipse Application(BundleException - lockstateChange)
Bundle Exception - Error when launching Eclipse Application [message #1734968] Tue, 14 June 2016 05:24 Go to next message
Good morning all,
I'm looking for hours now to fix this problem. When I want to run my DSL in the Eclipse application the following error appears and it won't lunch eclipse. I was looking on google and people suggested to delete the .lock file in the workspace in .metadata, but it didn't help.
The only thing which works is taking out my dsl project from the runtime-workspace, re-launching eclipse and reimporting it again. Then the "eclipse application" works again for 3-4 times launching and the error reappears. Then I have to redo the process again.
I'm currently working on Eclipse Neon, with Xtext 2.10.
Here the whole error message?
Thank you in advance for any help
Benjamin
!ENTRY org.eclipse.osgi 2 0 2016-06-14 11:18:01.006
!MESSAGE While loading class "org.eclipse.egit.core.Activator", thread "Thread[Worker-1,5,main]" timed out waiting (5008ms) for thread "Thread[main,6,main]" to finish starting bundle "org.eclipse.egit.core_4.4.0.201606011500-rc2 [136]". To avoid deadlock, thread "Thread[Worker-1,5,main]" is proceeding but "org.eclipse.egit.core.Activator" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="4.4.0.201606011500-rc2"; osgi.identity="org.eclipse.egit.core"; singleton:="true" [id=136] STARTED [STARTED]
	at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337)
	at org.eclipse.osgi.container.Module.start(Module.java:401)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:330)
	at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:357)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:349)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	at org.eclipse.egit.ui.Activator$RepositoryChangeScanner.run(Activator.java:617)
Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
	at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334)
	... 14 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2016-06-14 11:18:06.013
!MESSAGE While loading class "org.eclipse.egit.core.RepositoryCache", thread "Thread[Worker-1,5,main]" timed out waiting (5004ms) for thread "Thread[main,6,main]" to finish starting bundle "org.eclipse.egit.core_4.4.0.201606011500-rc2 [136]". To avoid deadlock, thread "Thread[Worker-1,5,main]" is proceeding but "org.eclipse.egit.core.RepositoryCache" may not be fully initialized.
!STACK 0
	at org.eclipse.egit.ui.Activator$RepositoryChangeScanner.run(Activator.java:621)
	... 14 more
Root exception:
Re: Bundle Exception - Error when launching Eclipse Application [message #1734969 is a reply to message #1734968] Tue, 14 June 2016 05:28 Go to previous message
looks like a question for the egit forum
Previous Topic:JVMInferrer: define a typeParameter for a generated class
Next Topic:getting the file path and accessing project files
Current Time: Mon Jul 21 05:13:26 EDT 2025
Powered by FUDForum. Page generated in 0.07943 seconds
