Home » Eclipse Projects » GEF » [GEF4] Calculation of stroke outline in model
[GEF4] Calculation of stroke outline in model [message #1734940] |
Mon, 13 June 2016 19:44  |
I have parts that render a PolyBezier using a stroke width that is specified by the model object. The model object is just storing the PolyBezier (which is infinitely thin) and an int for the stroke width. However, I'd like to be able to calculate the actual outline of the rendered geometry in the model code as well.
It's clear that something in either GEF4 or JavaFX is able to do this, as I can see that hit detection is using the outline of the stroke rather than just the actual model PolyBezier - I just can't see where this happens in the code.
The reason I need this is that I might have two shapes with different stroke widths that connect up, and rather than having an abrupt change from one stroke width to the other, I want to create a new connection object that has an outline that smoothly increases the stroke. To do that, I'd need to be able to identify points on the outer edges of the strokes, so that I can then create a polygon to join them together.
I'll try some ASCII art to illustrate. Imagine that each character is a pixel. The 'x' marks a waypoint on the model object. There are two lines, which share a common point at the third x. The first line has a stroke width of 3, so the 'a's represent the pixels filled by that line; the second line has a stroke width of 9, represented by the 'c's.
4ccccccccccccccccccccccccccccccc
cccccccccccccccccccccccccccccccc
aaaaaaaaaaaa1aaaaaaaaaaaaaacccccccccccccccccccccccccccccccc
xaaaaaaaaaaaxaaaaaaaaaaaaaxcccccccccccccccccxcccccccccccccx
aaaaaaaaaaaa2aaaaaaaaaaaaaacccccccccccccccccccccccccccccccc
3ccccccccccccccccccccccccccccccc
The points I want to identify are represented by numbers 1, 2, 3 and 4 - I would use these to create a polygon which would be rendered underneath the other two, represented by the 'o's here:
oooooocccccccccccccccccccccccccccccccc
oooooooooooocccccccccccccccccccccccccccccccc
I have come up with a couple of algorithms to generate these points, based on making a polyline approximation of the PolyBezier, then creating a series of polygons of the appropriate width using the straight lines as the centre. (Note, the version using Ring to join the polygons together produces a more accurate outline but has terrible performance).
However, it strikes me that something must already be doing this for hit detection to work. If it's happening in the JavaFX layer, then I probably can't use it in the model code, but if it's in the GEF4 layer then I should be able to use it. Where should I be looking?
Re: [GEF4] Calculation of stroke outline in model [message #1735200 is a reply to message #1735148] |
Thu, 16 June 2016 06:00   |
Hi Colin,
while it is true that curve offsetting is not supported by the Geometry component, yet, and the JavaFX functionality is indeed internal, the points that are needed can be computed using the Geometry component as follows:
1) Find the BezierCurve within the PolyBezier that contains the two "x" points before/at the joint of the two curves. This should either be the last or the second to last BezierCurve within the array returned by PolyBezier#toBezier().
2) Compute the first derivative of that BezierCurve in order to offset the point by the stroke width. The first derivative of a BezierCurve is called its hodograph and be accessed using BezierCurve#getDerivative().
3) Offset the "x" points by the stroke width. Suppose the first "x" point is called startPoint, and the last "x" point (i.e. the one at the joint) is called endPoint. The startPoint needs to be offset by the start curve's stroke width, the endPoint needs to be offset twice: once for the start curve's stroke width, and once for the end curve's stroke width.
The following snippet demonstrates the computation:
import org.eclipse.gef4.fx.utils.Geometry2Shape;
import org.eclipse.gef4.geometry.euclidean.Vector;
import org.eclipse.gef4.geometry.planar.BezierCurve;
import org.eclipse.gef4.geometry.planar.Line;
import org.eclipse.gef4.geometry.planar.Point;
import javafx.application.Application;
import javafx.scene.Scene;
import javafx.scene.layout.Pane;
import javafx.scene.paint.Color;
import javafx.scene.shape.Path;
import javafx.scene.shape.Polygon;
import javafx.scene.shape.StrokeLineCap;
import javafx.scene.shape.StrokeLineJoin;
import javafx.scene.shape.StrokeType;
import javafx.stage.Stage;
public class CurveOffsetSnippet extends Application {
launch();
protected void addCurves(Pane root, double y, boolean transition) {
// create curves
BezierCurve firstCurve = new Line(100, y, 200, y);
BezierCurve secondCurve = new Line(200, y, 300, y);
// create paths
Path firstPath = Geometry2Shape.toPath(firstCurve.toPath());
Path secondPath = Geometry2Shape.toPath(secondCurve.toPath());
// add to scene
root.getChildren().addAll(firstPath, secondPath);
// strokes
double firstStrokeWidth = 5;
double secondStrokeWidth = 15;
// configure strokes
firstPath.setStrokeType(StrokeType.CENTERED);
firstPath.setStrokeWidth(firstStrokeWidth);
firstPath.setStrokeLineCap(StrokeLineCap.BUTT);
firstPath.setStrokeLineJoin(StrokeLineJoin.BEVEL);
firstPath.setStroke(Color.DARKRED);
secondPath.setStrokeType(StrokeType.CENTERED);
secondPath.setStrokeWidth(secondStrokeWidth);
secondPath.setStrokeLineCap(StrokeLineCap.BUTT);
secondPath.setStrokeLineJoin(StrokeLineJoin.BEVEL);
secondPath.setStroke(Color.DARKRED);
// compute polygons to transition from the thinner/first curve to
// the thicker/second curve
if (transition) {
// compute start point and end point
Point startPoint = firstCurve.get(0);
Point endPoint = firstCurve.get(1);
// compute curve normals for start point and end point
Vector startNormal = new Vector(firstCurve.getDerivative().get(0))
.getOrthogonalComplement().getNormalized();
Vector endNormal = new Vector(firstCurve.getDerivative().get(1))
// compute left and right offset points for the start point (first
// curve stroke width)
Point startOffsetLeft = startPoint.getTranslated(
startNormal.getMultiplied(firstStrokeWidth / 2).toPoint());
Point startOffsetRight = startPoint.getTranslated(
.getNegated());
// compute left and right offset points for the end point (first
Point endThinOffsetLeft = endPoint.getTranslated(
endNormal.getMultiplied(firstStrokeWidth / 2).toPoint());
Point endThinOffsetRight = endPoint
.getTranslated(endNormal.getMultiplied(firstStrokeWidth / 2)
.toPoint().getNegated());
// compute left and right offset points for the end point (second
Point endOffsetLeft = endPoint.getTranslated(
endNormal.getMultiplied(secondStrokeWidth / 2).toPoint());
Point endOffsetRight = endPoint.getTranslated(
.getNegated());
// compute left and right polygons for a smooth transition between
// the stroke widths
Polygon leftPolygon = new Polygon(startOffsetLeft.x,
startOffsetLeft.y, endThinOffsetLeft.x, endThinOffsetLeft.y,
endOffsetLeft.x, endOffsetLeft.y);
Polygon rightPolygon = new Polygon(startOffsetRight.x,
startOffsetRight.y, endThinOffsetRight.x,
endThinOffsetRight.y, endOffsetRight.x, endOffsetRight.y);
// fill with stroke color
leftPolygon.setFill(Color.DARKRED);
rightPolygon.setFill(Color.DARKRED);
// add to scene
root.getChildren().addAll(leftPolygon, rightPolygon);
public void start(Stage primaryStage) throws Exception {
Pane root = new Pane();
Scene scene = new Scene(root, 400, 400);
addCurves(root, 100.5, false);
addCurves(root, 200.5, true);
primaryStage.setScene(scene);
primaryStage.show();
Re: [GEF4] Calculation of stroke outline in model [message #1735279 is a reply to message #1735200] |
Thu, 16 June 2016 18:02   |
Ah, so that's what a hodograph is used for, I wondered about that
Thanks Matthias, that's really cool. Actually, the shapes I'm joining together are constructed from QuadraticCurves rather than lines, so I have modified your example to create a PolyBezier from two new curves using the calculated offsets - I also offset the curve's control point in a similar manner to the start and end offsets. That produces a really beautiful effect, just what I was looking for. GEF4 rocks!
package nz.co.ctg.mote.client.test;
import org.eclipse.gef4.fx.nodes.GeometryNode;
import org.eclipse.gef4.geometry.planar.PolyBezier;
import org.eclipse.gef4.geometry.planar.QuadraticCurve;
public class QuadCurveOffsetSnippet extends Application {
launch();
// create curves
QuadraticCurve firstCurve = new QuadraticCurve(100, y, 150, y - 50, 200, y);
BezierCurve secondCurve = new QuadraticCurve(200, y, 250, y + 50, 300, y);
// create paths
// strokes
double firstStrokeWidth = 16;
double secondStrokeWidth = 48;
firstPath.setStroke(Color.BLUE);
secondPath.setStroke(Color.BLUE);
if (transition) {
Point controlPoint = firstCurve.getCtrl();
Vector startNormal = new Vector(firstCurve.getDerivative().get(0)).getOrthogonalComplement().getNormalized();
Vector endNormal = new Vector(firstCurve.getDerivative().get(1)).getOrthogonalComplement().getNormalized();
Point startOffsetLeft = startPoint.getTranslated(startNormal.getMultiplied(firstStrokeWidth / 2).toPoint());
Point startOffsetRight = startPoint.getTranslated(startNormal.getMultiplied(firstStrokeWidth / 2).toPoint().getNegated());
// compute left and right offset points for the quadratic curve control point
Point ctrlOffsetLeft = controlPoint.getTranslated(startNormal.getMultiplied(firstStrokeWidth / 2).toPoint());
Point ctrlOffsetRight = controlPoint.getTranslated(startNormal.getMultiplied(firstStrokeWidth / 2).toPoint().getNegated());
Point endOffsetLeft = endPoint.getTranslated(endNormal.getMultiplied(secondStrokeWidth / 2).toPoint());
Point endOffsetRight = endPoint.getTranslated(endNormal.getMultiplied(secondStrokeWidth / 2).toPoint().getNegated());
// compute left and right curves for a smooth transition between
BezierCurve left = new QuadraticCurve(startOffsetLeft, ctrlOffsetLeft, endOffsetLeft);
BezierCurve cap = new Line(endOffsetLeft, endOffsetRight);
BezierCurve right = new QuadraticCurve(endOffsetRight, ctrlOffsetRight, startOffsetRight);
PolyBezier cone = new PolyBezier(left, cap, right);
// add to scene
GeometryNode<PolyBezier> coneNode = new GeometryNode<PolyBezier>(cone);
coneNode.setFill(Color.BLUE);
coneNode.setStroke(Color.BLUE);
coneNode.setStrokeLineCap(StrokeLineCap.BUTT);
coneNode.setStrokeLineJoin(StrokeLineJoin.BEVEL);
root.getChildren().add(coneNode);
// add to scene
Re: [GEF4] Calculation of stroke outline in model [message #1735302 is a reply to message #1735282] |
Fri, 17 June 2016 04:32   |
Hey that looks cool indeed!
I manipulated the code further to accurately align the shapes:
- Compute control points for cones so that C1 continuity is achieved.
- Set stroke to transparent for the cones to properly align the shapes.
if (transition) {
// compute start point and end point of the transition curve
// compute derivatives for start/end
BezierCurve derivative = firstCurve.getDerivative();
Vector startDirection = new Vector(derivative.get(0));
Vector endDirection = new Vector(derivative.get(1));
Vector startNormal = startDirection.getOrthogonalComplement()
.getNormalized();
Vector endNormal = endDirection.getOrthogonalComplement()
.getNormalized();
.getNegated());
.getNegated());
// compute control points by intersecting the derivatives through
// the offsetted start/end points to achieve C1 continuity
Straight s1Left = new Straight(new Vector(startOffsetLeft),
startDirection);
Straight s2Left = new Straight(new Vector(endOffsetLeft),
endDirection);
Vector ctrlOffsetLeft = s1Left.getIntersection(s2Left);
if (ctrlOffsetLeft == null) {
ctrlOffsetLeft = new Vector(endOffsetLeft);
Straight s1Right = new Straight(new Vector(startOffsetRight),
startDirection);
Straight s2Right = new Straight(new Vector(endOffsetRight),
endDirection);
Vector ctrlOffsetRight = s1Right.getIntersection(s2Right);
if (ctrlOffsetRight == null) {
ctrlOffsetRight = new Vector(endOffsetRight);
org.eclipse.gef4.geometry.planar.Path leftCone = new org.eclipse.gef4.geometry.planar.Path(
new Segment(Segment.MOVE_TO, startOffsetLeft),
new Segment(Segment.QUAD_TO, ctrlOffsetLeft.toPoint(),
endOffsetLeft),
new Segment(Segment.LINE_TO, endPoint),
new Segment(Segment.QUAD_TO, firstCurve.getCtrl(),
startPoint),
new Segment(Segment.CLOSE));
org.eclipse.gef4.geometry.planar.Path rightCone = new org.eclipse.gef4.geometry.planar.Path(
new Segment(Segment.MOVE_TO, endOffsetRight),
new Segment(Segment.QUAD_TO, ctrlOffsetRight.toPoint(),
startOffsetRight),
new Segment(Segment.LINE_TO, startPoint),
endPoint),
Line capLine = new Line(endOffsetLeft, endOffsetRight);
// create corresponding JavaFX shapes
Path leftConeShape = Geometry2Shape.toPath(leftCone);
Path capShape = Geometry2Shape.toPath(capLine.toPath());
Path rightConeShape = Geometry2Shape.toPath(rightCone);
// style the shapes for accurate alignment
leftConeShape.setStroke(Color.TRANSPARENT);
leftConeShape.setFill(Color.BLUE);
rightConeShape.setStroke(Color.TRANSPARENT);
rightConeShape.setFill(Color.BLUE);
capShape.setStroke(Color.BLUE);
capShape.setStrokeLineCap(StrokeLineCap.BUTT);
// add to scene
root.getChildren().addAll(leftConeShape, capShape, rightConeShape);
Screenshot:
Matthias
[Updated on: Fri, 17 June 2016 04:34] by Moderator
Re: [GEF4] Calculation of stroke outline in model [message #1735380 is a reply to message #1735302] |
Fri, 17 June 2016 20:00  |
Awesome, that looks great. I also tried the same approach on calculating the fat outline - it's pretty good except for the degenerate case where the control point is actually on the curve (i.e. it's really a straight line). In that case I just calculated the offset as the midpoint between the two curve offset points. Apart from that, it gives a really good fat outline - on very wide lines with sharp curves, it overestimates the control points just a bit, but otherwise a very good fit, and with excellent performance.
Current Time: Sat Jul 26 00:41:36 EDT 2025
Powered by FUDForum. Page generated in 0.25529 seconds
